SailNet Community (https://www.sailnet.com/forums/)
-   Gear & Maintenance (https://www.sailnet.com/forums/gear-maintenance/)
-   -   Parker R12P Fuel/Water Separator (https://www.sailnet.com/forums/gear-maintenance/67705-parker-r12p-fuel-water-separator.html)
bobmorning 08-25-2010 07:50 PM
The Parker R12P has two outlets under the clear polycarbonate bowl, one is black with finger grips, the other is fitting with a slotted screw fitting.
Which one do I open to drain the water, I'm assuming the black one since it has finger grips and has a hose barb on the end of it? When I started to open it I could see air bubbles floating up.
That alarmed me as I was concerned that I would introduce air into the line and it's subsequent problems.
Any info much appreciated.
Bob
RichH 08-25-2010 08:46 PM
The hose barb should have a small diameter long length tube attached when draining water. The application of a tube will slow down or prevent the in-rush of air through the drain and allow the tank to siphon to prevent air intrusion into the filter bowl.
You should however plan on bleeding air anytime you open a fuel filer. A 12vdc electric fuel pump mounted in-line between the tank and the filter set will save a lot of 'hassle' when you need to bleed.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
