The Jabsco Macerator... a ticking bomb of nastyness - Page 3 - SailNet Community
 1Likes
post #21 of 23 Old 02-09-2017
Re: The Jabsco Macerator... a ticking bomb of nastyness
Originally Posted by eherlihy View Post
My Jabsco macerator made an off-pitch whine when I last ran it in October. I just purchased a Raritan Macerator with stainless steel bolts as a spare. I hope that it lasts as long as my Jabsco, which has been on board and in service since before 2010.
Just curious, are you waiting for it to fail or you know it has failed?
Keep us posted on the replacement work - I may soon be facing the same pleasure....
SVTatia is online now
post #22 of 23 Old 02-09-2017
fallard's Avatar
FWIW, after replacing a Jabsco macerator twice over the years in my sailboat, I switched to Shurflo with the understanding that it has a longer run-dry time. That was several years ago. So far, so good.
I also use a Jabsco macerator in my powerboat to pump out the fish boxes and have had to replace it about every 5 years when it started blowing fuses or refused to run. I attribute that to the run-dry issue, as the pump has to self-prime for several seconds before pulling water through. I had been stuck with Jabsco replacements because I could not remove the hoses from the pump bell and therefore had a compatibility issue with replacing just the motor/pump and attaching it to the original 1990 bell.
You can understand why I am not a fan of Jabsco macerators.
fallard is online now
post #23 of 23 Old 02-09-2017
Funny to see such an old post of mine. The Jabsco mascerator I referenced did eventually go. I too would have described it as whining, but it was also having difficulty priming itself. At first, it wasn't bad enough that I was convinced it was taking too long to prime. Eventually, it was obvious.
I swapped it out with a Shurflo. The first time I hit the switch, prime was instantaneous and pumping was strong.
It's a crappy job. Mine, as I mentioned above, is buried deep too.
Jeanneau 54DS
Minnewaska is offline
Atomic Is No Bomb sailnaway Atomic 4 9 10-21-2011 01:43 PM
Atomic bomb? Barquito Gear & Maintenance 15 05-07-2010 11:20 AM
Jabsco macerator pump not pumping just whinning. SanDiegoChip Gear & Maintenance 10 01-29-2010 03:17 PM
atomic bomb QuickMick Gear & Maintenance 20 12-10-2009 11:05 AM
Jabsco Macerator Pump aruggiero Gear & Maintenance 0 08-31-2009 02:56 PM
