My Hurth is supposed to.... - Page 4 - SailNet Community
 1Likes
post #31 of 52 Old 07-25-2011
Learning the HARD way...
eherlihy's Avatar
One more thing... While I agree that the BEST way to drain the fluid (again, Dextron III) would be through the plug, I don't do it that way. I use my Oil change vacuum pump
to suck the ATF out from the top in the fall. I suck all of it out, then pour an entire quart of new fresh ATF into the transmission (in addition to displacing moisture, it keeps the seals from drying out too). In the spring I suck the ATF out until I reach the correct level.
There are many posts elsewhere about the fact that the drain plug is steel, and the threaded drain hole, that you cannot see, on the bottom of the transmission case is aluminum (guess which will strip first). Also, it ain't leaking, and I don't want it to start.
deniseO30 likes this.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #32 of 52 Old 07-25-2011
Tartan 27' owner
CalebD's Avatar
A4 vs Diesel Hurth
Most Atomic 4 setups do not use the Hurth transmission.
With the A4 engine you are supposed to leave it in fwd when sailing as reverse uses the reverse clutch.
IIRC, the Hurth tranny 'likes' to be put into reverse when sailing. Is that right?
Originally Posted by deniseO30 View Post
Well, first thing I've noticed; the shift into fwd or rev needs almost no effort now.
Phoxie. I don't think you have a Hurth Trans on the A4
Everybody has one:
CalebD is offline
post #33 of 52 Old 06-05-2018
Re: My Hurth is supposed to....
My Hurth HBW50 is slipping in forward. Once in engages it stays engaged.
Someone told me to run paint thinner in it and click through forward and reverse several times until it consistently engages. then drain and refill again.
Sound crazy??
Please send me recommendations.
Last edited by Ron DeRu; 06-06-2018 at 04:21 PM. Reason: I should not have put my email in there.
Ron DeRu is offline
post #34 of 52 Old 06-06-2018
Update! changed the fluid. it was dark dark brown almost black. new is red. will change it again in a few weeks. Changed the engine oil too. hot nasty work!
Did you drain from the bottom or took out from the top?
Did you replace the crush washer? I had a hard time finding a new washer (HBW 50), finally a Honda dealer saved me....
SVTatia is offline
post #35 of 52 Old 06-06-2018
First, this thread is 7 years old and the OP sold her boat a couple of years back. Since this is an unrealted query, I'll add to it.
Sounds like worn plates or thrust bearing. As they slip, the friction causes heat which expands them just enough to work. Consider it a warning for imminent complete failure. BTDT. In my case, forward was slipping, reverse worked fine. Of course, forward was used substantially more, resulting in more wear.
Sound crazy??
Yes
Jeanneau 54DS
Minnewaska is offline
post #36 of 52 Old 06-06-2018
Minnewaska
Thank you for the advise! I'm scheduling a tran replacement. Unfortunately everyone is booked for the summer. Trying to find a work around. For now I have installed a LH prop, so to go forward I put it in reverse. This has worked for me but of course I have no reverse and an emergent situation will be problematic. Seems like 700 hours on a transmission is very little. I'm not impressed with Hurth. Any recommendations?
Ron DeRu is offline
post #37 of 52 Old 06-06-2018
Ron-
I think that "logically" the only thing that paint thinner could do, being a solvent, would be to dissolve any accumulated varnish or buildup that was making the transmission slip. And to quote an old tv show, "Homey don't think so."
I don't think anyone's idea of a fun weekend is to pull out and dismantle a transmission, but you might want to have that pulled and overhauled, so you can be SURE that you won't get stuck someplace when the situation is worse.
Not to mention, who knows what is in generic "thinner" and how seals or other parts might react to it over the longer term.
hellosailor is offline
post #38 of 52 Old 06-06-2018
Control linkage should be in centre of FNR detent when in N Then ensure travel each way is enough to push the cones.
Capt Len is online now
post #39 of 52 Old 06-06-2018
Not sure how buried the gear is in your boat. I could get mine out in 30 mins, if it was on the hard. It took a nearby tranny shop one week to turn around a rebuild. These are very simple gears.
If I had the right presses and calipers, Im convinced I could have done it myself. Rebuild kits are available. Not that I had the time, nor inclination.
I dont think there is anything inherently wrong or inferior with a ZF/Hurth gear. Hours are not always a good indicator. Some gears are oversized for the boat, others are undersized. Does the captain hammer the gear hard to manage current or stop a boat in a slip. Lots of variables.
I bought my current boat with about 400 hrs on the engine/gear. It was showing signs already and crapped out on me around 1000 hrs.
Jeanneau 54DS
post #40 of 52 Old 06-06-2018
Guys, Thanks for all the help.
I already checked for a full throw on the shifter. That's not the problem.
Catalina 34 requires a complete engine lift/removal to get at the transmission.
Furthermore the engineers put the trans mounting bolts INSIDE the bell housing (the turds).
Got one estimate for $6500 to do the job.
Another estimate for $2500 but I don't think they realize the scope of the work.
Another party said trans shops will not rebuild the HBW50 anymore. "too many moving parts, can't warranty the work"
Another party recommended the PRM60D2.
This is a decision above my pay grade,
signed ... screwed.
Ron DeRu is offline
Hurth HBW-5 Transmission KVK Diesel 16 01-28-2016 08:19 PM
Hurth HBW-5 won't shift mwielicki Gear & Maintenance 1 04-16-2010 11:55 PM
Is a propane Solenoid supposed to be hot ??? Sailormann Gear & Maintenance 15 05-27-2009 11:31 AM
Hurth HBW 50 vs. ZF-5, ZF-6 or ZF-10 Pub911 Gear & Maintenance 2 02-03-2009 07:44 AM
Hurth tranny on way to DOA halyardz Gear & Maintenance 1 09-09-2002 07:40 AM
