SailNet Community (https://www.sailnet.com/forums/)
-   Gear & Maintenance (https://www.sailnet.com/forums/gear-maintenance/)
-   -   Nylon or Dacron ? (https://www.sailnet.com/forums/gear-maintenance/7679-nylon-dacron.html)
Strega 08-07-2003 12:51 PM
Nylon or Dacron ?
Is there an easy way to tell the difference between nylon and dacron lines ?
goduke 08-07-2003 05:10 PM
Nylon or Dacron ?
I guess we can asume that you''re talking about older line. Generally, nylon has more stretch/elasticity. However, as it ages it gets stiffer and it becomes harder to tell - especially with less expensive "non-marine" cordage.
Can you provide a little more information - like why you are asking this question?
Strega 08-08-2003 03:15 AM
Nylon or Dacron ?
New boat with a stash of old double braid line. Some of it appers to be in decent shape. I have some uses for both materials.
goduke 08-08-2003 09:03 AM
Nylon or Dacron ?
Chances are that,if it is double braid,it is dacron. Although, there are some manufacturers that make dock lines that are braided. Also, if the diameter is less than 7/16" or so, the lines are probably old dacron sheets, halyards or control lines. Of course, the size of your boat also matters. Its still pretty hard to generalize without seeing them.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
