SailNet Community (https://www.sailnet.com/forums/)
-   Gear & Maintenance (https://www.sailnet.com/forums/gear-maintenance/)
-   -   replacement diaphram on bilge pump needed (https://www.sailnet.com/forums/gear-maintenance/83533-replacement-diaphram-bilge-pump-needed.html)
Gill L 02-06-2012 08:24 AM
Hi, I need to replace the diaphram on my manual bilge pump in my 1980 Union 36. I am unable to find a manufacturer's name on the pump, but the diameter of the rubber (?) diaphram is 10 inches. Anyone out there have any suggestions? Thanks
Tim R. 02-06-2012 08:40 AM
Probably a Whale pump. Many Gusher 10s were installed as bilge pumps. See the link to see if yours matches any of them.
Whale Marine - Products
olson34 02-06-2012 01:25 PM
While the pump might be a stock item from someone like Whale, there is also the chance that, like the knock-off winches that overseas builders used to make, they may have done the same with a pump.
Diaphram pump designs are kinda generic anyhow...
As long as the rest of the parts are in good order, perhaps you could source some reinforced rubber fabric and cut out a new diaphram, maybe.
:confused:
Brent Swain 02-06-2012 07:44 PM
Edson makes some pumps that size.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
