Is there a NON THRU HULL Knotmeter?!?! - Page 3 - SailNet Community
 6Likes
post #21 of 25 Old 05-08-2019
Minnesail's Avatar
Re: Is there a NON THRU HULL Knotmeter?!?!
I realize this is a very old thread that got resurrected, but it's interesting.
Has anyone used one of the ultrasonic speed sensors? Paddlewheels seem like such a pain in the pita.
AIRMAR UDST800 Ultrasonic Smart™ Sensor
Catalina 22
on a starboard tack
Minnesail is online now
post #22 of 25 Old 05-08-2019
overbored's Avatar
I use the Airmar CS4500 speed and temp. it is about 4 years and works very well. dead on calibration never varies. we use a thru hull depth sensor but almost never look at it. no thin water here.
Minnesail likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #23 of 25 Old 05-08-2019
Minnesail's Avatar
Originally Posted by capta View Post
The point is, the ultrasonic speed sensors and GPS are exactly the same. They tell you speed over the ground. A paddle wheel gives you speed in relation to the water you are in, two completely different things.
If you have a good GPS plotter, it's pretty easy to see set or drift on the screen, otherwise, it is nice to have both speed sensors to help determine current.
Really? I thought they were using some ultrasonic magic to measure water turbulence or something to give you speed through water.
Catalina 22
on a starboard tack
post #24 of 25 Old 05-08-2019
overbored's Avatar
not the same. the ultrasonic reads the particles in the water with two sensors a set distance apart to determine the speed thru the water, GPS works off a satellite and is slow to react.
post #25 of 25 Old 05-08-2019
Master Mariner
capta's Avatar
Yeah. I guess there are newer ones.
Sorry, wrong again. My bad.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
Tags
knotmeter speedometer
GPS vs Knotmeter skyamsen Gear & Maintenance 13 12-26-2011 06:13 PM
A Few Knotmeter Questions... JedNeck General Discussion (sailing related) 6 10-11-2011 05:18 PM
Plugging Old Knotmeter Hull Holes casey1999 Gear & Maintenance 25 04-08-2011 12:24 PM
Used Knotmeter Finallybuyingaboat General Discussion (sailing related) 6 09-28-2009 08:57 AM
MacGregor 25 Knotmeter troutguy General Discussion (sailing related) 5 01-11-2009 12:39 PM
