Gauge of wires to use - SailNet Community
 3Likes
  • 1 Post By asdf38
  • 1 Post By RichH
  • 1 Post By MarkSF
post #1 of 10 Old 06-18-2012 Thread Starter
I need to do some electrical work - install radio station, music player, etc. What gauge of wires would I need for those?
Also, I want to be able to charge cellphones on the boat - can someone recommend a device? I think usb exit would be good, car plug might be ok too.
Romario is offline
post #2 of 10 Old 06-18-2012
asdf38's Avatar
Re: Gauge of wires to use
The West Advisor: Marine Wire
That's a good starting point. Get only good quality marine wire. I suggest Ancor brand duplex safety cable. 12V is red, GND is yellow (yes yellow to avoid confusion with AC ground if present).
I suggest getting a quantity of 14 or 16 awg, and the appropriate adhesive lined shrink crimps. Also make sure you have the appropriate fusing. Look for bluesea brand terminal blocks, fuse blocks, fuses and other things.
Ancor Marine Grade Flat Duplex Safety Electrical Cable
Ancor Ring Terminals (Heat Shrink)
For charging you can wire in a lighter plug outlet and then get an automotive 12V usb charger. This lets you use other lighter plug items if you need too.
chef2sail likes this.
Precision 18, Massachusetts
Former boat: Contessa 26
asdf38 is offline
post #3 of 10 Old 06-18-2012
The NEC rules for wire guages are the minimum Dia wire for the current so the insulation doesn't melt. Not what you really want for marine enviroment.
Without more information, (I'm assuming 12v devices). And not a very long run 16 guage should be plenty. For longer runs, it may be 20-30 ft from the battery to the panel, then another 10-20ft to the devices, 12 guage should be fine, (not for the current, but to minimise voltage drop).
To charge my cell phone I installed a car style 12 volt socket, and bought a car charger for my cell phone. For the phones that have usb style charger ports, I bought a 12v to usb charging adaptor.
I hope this helps. If you need more info, you need to give more details about the specific install you are doing. WHat kind of radio, what wattage etc... size of boat, distance from panel?
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #4 of 10 Old 06-18-2012
the pointy end is the bow
erps's Avatar
Wires are sized for how many amps you want to run through them and the distance of the wire. Once you select your wire size, then you install "protection" in the form of a fuse or a circuit breaker that trips before the amp capacity for your particular wire has been exceeded.
Here is an example of a table for selecting your wire size. Scoll down to the 12 volt table.
DC Wire Table
geez the guys are quick today. three responses in about a minute.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #5 of 10 Old 06-18-2012
Commodore
n8kraft's Avatar
Gage of wire
The gage of wire you well use depends on the length of the run and number of amps of max current draw. Check out the book Sailboat Electrics Simplified by Don Casey
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
post #6 of 10 Old 06-18-2012
RichH's Avatar
Here ya go ... based on the total run (in ft.) of the wire: AWG by wire length/amps calculator
... and for 'boats' dont use less than 18 ga. for small wiring primary 'hook-ups'.
dacap06 likes this.
RichH is offline
post #7 of 10 Old 06-18-2012 Thread Starter
About the length - not too far from the main electrical box and the batteries. I would think not more than 10ft.
The radio I have is STANDARD HORIZON GX1150 Eclipse DSC+ (or something very similar, I don't remember exactly).
Stereo - I want to reuse the one I had in the car:
Alpine FM/AM CD Receiver OWNER'S MANUAL CDA-9827, CDA-9826, CDA-9825 | ManualsOnline.com
by the way - do you think it will last or will it completely corrode? I am in salty water. I don't mind if it will break after some time, I have no good use for it anyway.
Romario is offline
post #8 of 10 Old 06-18-2012
I recommend this book which includes a chapter on electrical work.
http://www.amazon.com/Caseys-Complete-Illustrated-Sailboat-Maintenance/dp/0071462848/ref=sr_1_3?s=books&ie=UTF8&qid=1303148437&sr=1-3
MarkSF is offline
post #9 of 10 Old 06-18-2012 Thread Starter
Already put that book in my Amazon cart, so was looking what else do I need :-)
Here is what is there so far:
United States Hdwe. R-011B Putty Tape (Butyl Tape)
3M Company 3/4X66 Scotch Elec Tape 4218-Ba-40 Electrical Tape & Shrink Tubing
Chart No. 1: Symbols, Abbreviations and Terms - NOAA NOAA; Paperback
and the book you recommended.
Wanted to put some wires there as well. I think some 18AWG and some 16AWG should be ok for now.
Romario is offline
post #10 of 10 Old 06-18-2012
Forget the 18 gauge and double up on the 16.
ABYC recommends that no wire thinner than 16 gauge is used on a boat, no matter how low the current. This is because the wire needs to have a certain strength to resist damage.
These days I keep a long length, like 30ft, of 16 gauge, 2 core, Boat Cable on the boat, so most of the time I've got what I need whenever I'm installing small stuff like radio, instruments, etc.
dacap06 likes this.
MarkSF is offline
How to join big wires to little wires preservedkillick Gear & Maintenance 9 04-10-2009 09:01 PM
wires going up the mast - where do they go in? jarcher Gear & Maintenance 4 10-10-2008 04:43 PM
Securing Wires jbondy Gear & Maintenance 4 07-02-2008 03:33 PM
How many wires are too many? jaschrumpf Gear & Maintenance 14 07-27-2007 10:12 AM
Wires through deck brak Gear & Maintenance 12 06-16-2007 10:36 PM
