Porthole. Re-build - SailNet Community
 1Likes
  • 1 Post By mbowser
post #1 of 4 Old 08-09-2012 Thread Starter
Porthole. Re-build
Hello,
I have got a '79 Formosa with some very bad looking bronze portholes. As you can see on the photo, there are some dark (black) corroded areas. It looks like the bronze has been plated on top of an other metal. Can that be right? Does anybody know how to get them nice and polished again?
steenbn is offline
post #2 of 4 Old 08-09-2012
BJV
Re: Porthole. Re-build
They are old brass ones and pretty rugged. I had a few which were real bad and replaced them with ones made by Newfound Metals. The others I removed and rebeded, using a drill with a bronze wire brush to clean them up.
bvander66 is offline
post #3 of 4 Old 08-10-2012
mbowser's Avatar
If your not afraid to experiment, this is what I'm doing:
Magic #16: Fun With 10 Amps and a Bucket of Caustic Solution
You need to pull the ports off the boat though.
peterchech likes this.
mbowser is offline
post #4 of 4 Old 08-11-2012
That is cool!
I had a similar issue with my outboard bracket mounts, the aluminum was pitted and corroded so I wanted to clean them up and paint them for added protection. Sanding the deeply pitted corroded parts would have been impossible to do right. I have a friend with access to a small boxed in sandblaster. Took about 2 minutes per piece and every single bit of corrosion was gone, leaving just the clean metal underneath. Machinist shops often have these units that may work for you as well, though the electrolysis method might leave a shinier and easier to polish finish.
peterchech is offline
Tags
port hole , porthole , portlights
Porthole sealing question(s) rookie00 Gear & Maintenance 9 07-03-2015 09:09 PM
DIY Porthole Gaskets ReddOne Gear & Maintenance 20 06-22-2012 05:59 PM
porthole covers charlienpam General Discussion (sailing related) 7 06-13-2010 08:38 AM
Porthole Question Alden68 General Discussion (sailing related) 2 04-28-2007 11:06 PM
oday 272 porthole gaskets pats29 Gear & Maintenance 0 04-24-2002 06:45 PM
