Ratcheting winch handle - Page 2 - SailNet Community
 3Likes
post #11 of 40 Old 08-11-2012 Thread Starter
Re: Ratcheting winch handle
ok thank you
AndreasNYC is offline
post #12 of 40 Old 08-11-2012
If you find a source let me know. I have a winch on the mast that is obstructed and could use a ratcheting handle also.
LinekinBayCD is offline
post #13 of 40 Old 08-12-2012
Junior member, rest old
msmith10's Avatar
It is correct that they are not made anymore. I sold one a year ago on ebay. As above, watch consignment shops or ebay- they do show up once in a while. South Coast made one at one time. Try calling Minneys.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #14 of 40 Old 08-12-2012
Wish I never found SN!
SimonV's Avatar
I would just relocate the stanchion, not a hard Job and probably cheaper.
RichH likes this.
Simon
Bavaria 50 Cruiser
Mediterranean
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #15 of 40 Old 08-12-2012
Not sure of a retail source off hand, but have seen several references to 12" winch handles over the years. Perhaps a bit of extra leverage would help?
Others have pondered the question, too:
http://sailing.about.com/b/2009/09/2...nch-handle.htm
FWIW dept: we have a T-handle 10" that is oodles better than the standard handle. At least one can get more upper body strength into the rotation....
Note B: You might also re-think the location and angle of your primaries. Almost all production boats have their winch bases angled outward due to the overall angle of the top of the combing. This made the original tooling a bit less expensive, looks proper when viewed at the boat show, but leaves the grinders having to reach outward, away from their core strength.
It's fine for a tall and muscular 20-something guy, but terrible for everyone else. After some diagraming and a mockup, we added some risers under ours and changed the angle to bring the winches level.
Now they are much much (much!) easier to use.
olson34 is online now
post #16 of 40 Old 08-12-2012
I'd rather be sailing....
afrinus's Avatar
Just buy a socket ratchet from Sears and make up your own.
RichH and capta like this.
"Boat-less no more...
afrinus is offline
post #17 of 40 Old 08-12-2012
fryewe's Avatar
If you buy a ratcheting drive from a hardware store for this you will need to baby it to prevent corrosion inside the mechanism. It will require frequent flushing and liberal treatment with a corrosion inhibitor. Or just replace it frequently. You can pick up used half inch ratchet drives for a few bucks and carry a whole toolbox full of them for what you will pay for one ratcheting winch handle.
fryewe is online now
post #18 of 40 Old 08-12-2012
Old as Dirt!
svHyLyte's Avatar
Originally Posted by AndreasNYC View Post
Hello Everyone
I have 2 speed winches on my boat.
Unfortunately there is not enough clearance around the winches (for the jib lines) to rotate all the way around.
This means you have to move the handle back and forth rather than around.
When the tension gets beyond a certain point, the "fast" direction of the winch become too hard to move.
The solution would be a ratcheting winch handle that will only engage in the "slow" direction.
any idea where I can obtain some?
Andreas
Andreas--
Consider using a Winchbit with a 10" or 12" socket wrench. It works, in both directions, and overall will be less costly than another winch handle.
FWIW...
svHyLyte is offline
post #19 of 40 Old 08-12-2012
JordanH's Avatar
Hi AndreaNYC,
How much is the constraint? Our Contessa 26 has the winches too close to the stanchions ... for a 10" winch handle. The 8" is fine. We decided to stay with the 10" handle and ratchet it on our single-speed winches as the extra leverage and handle feels better.
Instead of a ratchet, would a shorter handle work in your case?
JordanH is offline
post #20 of 40 Old 08-12-2012
Bristol 45.5 - AiniA
Also try Bacon's in Annapolis. They have a lot of consignment gear for sail. If you can fine one it will be pricey because they were never common and there is quite a bit of demand. I bought a used one some years ago and it was much more than a new, standard handle. I would not worry about dropping it over the side - with the price and difficulty finding one you will be extra careful.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
Looking for an old winch handle j1brady Gear & Maintenance 22 10-01-2010 09:37 PM
winch handle marthajewel Gear & Maintenance 7 02-25-2009 11:57 AM
Winch Handle Maintenance tdw Gear & Maintenance 9 10-23-2007 08:42 PM
Winch Handle - Lock-in TejasSailer Gear & Maintenance 3 04-29-2006 10:30 PM
Barlow winch handle. jensw Gear & Maintenance 1 02-22-2006 09:48 AM
