Hi Mod fittings - SailNet Community
 4Likes
post #1 of 19 Old 11-29-2012 Thread Starter
casey1999's Avatar
Hi Mod fittings
I am planning to replace all standing rigging on my boat. Plan to use Hi Mod mechanical fittings on the lower wires and maybe uppers. Looking for comments on the Hi Mods:
1. Have you ever had a failure?
2. Did you use a sealant in the fitting (like silicone)?
3. Should I use Hi Mods on the upper wire fitting or go with a swage fitting?
4. Any other comments?
casey1999 is offline
post #2 of 19 Old 11-29-2012
Super Moderator
Maine Sail's Avatar
Re: Hi Mod fittings
We have Norseman's, Sta-Lok and Hi-Mod fittings on our boat. Wanted to try them all. I like the Hi-Mod's the best and the Norseman's the least. Don't know of any failures of any of them but I am sure you can find them.
Hayn does not require a sealant in the Hi-Mod fittings just a thread locker during assembly. I used swages on the upper end and mechanical on the lower ends..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 19 Old 11-29-2012 Thread Starter
casey1999's Avatar
Re: Hi Mod fittings
I see the Hi Mod instructioins say no sealant required (only locktite), but will salt water be held by the fitting, or can it drain out (so as to not cause corrosion)?
Why not use mechanical fittings on the uppers instead of swage?
For swage fittings is a sealant used before swaging? I know some swage fittings looks like some type of sealant is in the swage.
post #4 of 19 Old 11-29-2012
DrB
Interesting
I literally just got my entire rig redone and the rigger that I used said he thinks Hi-Mods are absolute junk. I think he gave me Noreseman's after much discussion. I did a lot of research on the various fittings when we discussed and he said Sta-Lok or Norseman only. There was a reason why he said a lot of DIY riggers use Hi-Mods (I can't recall), but he would never put them on any boat that he did.
As far as the rigger, when I asked who to use for a rigger around my area, everyone gave me his name.
YMMV
wdwright1967 likes this.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #5 of 19 Old 11-29-2012
Re: Interesting
YMMV
Well, it would be helpful to know WHY the guy believes that HiMod fittings are 'junk.' Without that information, this statement is not very informative.
MastUndSchotbruch is online now
post #6 of 19 Old 11-29-2012
Super Moderator
Maine Sail's Avatar
Re: Interesting
YMMV
May want to ask him to qualify "junk".. I know lots of professional riggers who use Hayn Hi-Mods as well as piles of other Hayn equipment. I got mine from my local rigger who is very well respected in this area. The only complaint with them is that they are actually tougher to do than a Norseman or Sta-Loc when installing them at a boat. In a shop, with a vise, they are easy but not so much without the right tools. My head stay has a Norseman because it was easier to build on-site than a Hi-Mod but the darn thing is all rusty....
Carl Hayn is one of the most reputable guys in the industry and I've never know him to produce "junk" if he was he'd have long ago been out of business...
As for "junk" my Norseman's rust so badly that I need to treat/clean them with Spotless Stainless once or twice per season. The Sta-Loc and Hayn's stay free of rust..
From left to right: Sta-Loc, Norseman & Hi-Mod (all the same age)
______
post #7 of 19 Old 11-29-2012 Thread Starter
casey1999's Avatar
Re: Hi Mod fittings
FWIW,
Before buying the Hi Mod, I did a lot of research (every sailing publication I could find). Everthing I found said the Hi Mods were best, although all were good. Nothing was called junk (at least among Hi Mod, Norseman, and Sta Lock).
post #8 of 19 Old 11-29-2012
Super Moderator
Maine Sail's Avatar
Re: Interesting
YMMV
Here's what the current "Godfather of rigging" Brion Toss has to say...
This was in regards to a question froma guy re-rigging an Oyster 55 and wondering about using Hayn Hi-Mods.
Originally Posted by Brion Toss (From his own forum)
Hello,
Especially with the fairly large wire you need, Norseman is out of the running. Harder to form, weakens the wire more than the competition. I'm very reluctant even to install them any more.
Sta-Lok is a very good second choice. Fairly easy to form with big wire, easily sealed, fairly strong. And great customer support from the importer, Sailing Services.
Hayn, though is the winner. They make the only terminal that is 100% strength efficient. Sta-Loks typically break in the 90's -- and has anyone seen any Norseman results higher than the 80's? -- and they are very easy to assemble, as you do not bend the yarns, and there is a nifty castellated spacer for the yarns to settle into during assembly. Also the prettiest terminal. Many places sell them for much more than the competition, but if you shop around you can get comparable prices.
As for the wedge issue, Hayn is also quite strong on customer service. Give 'em a call.
Fair leads,
Brion Toss
I think Brion Toss like Nigel Calder, Steve D'Antonio and other "experts in their field" has a pretty good track record....
______
post #9 of 19 Old 11-29-2012
DrB
I will ask, but if IRCC
something about the assembly process and the need to be very careful not to over torque that they were more susceptible to galling.
DrB
EDIT - I think the rigger I used had a very bad experience with earlier Hi-Mods and that made him against them today. He is a Navtec man and this is what he wrote back.
"Hi mods are awful, used them once, never again. They don't use Navtec, they use Hayn ends. Good stuff, not the best." - Translate however you want.
In another email they wrote this:
"The wire we use is type 316 Mil Spec, and has the highest rating we can find. We use Sta lok turnbuckles and Norseman mechanical ends for our big boat offshore customers. The upper ends are Navtec type 316 swaged by our own Electric Hydraulic swager. We have done work for the US Navy and other high end military and commercial applications. We are at the highest end of the certification given by the industry. To your point, the quote is done as if it were my Pearson 10M with my family on board.."
DrB is offline
post #10 of 19 Old 11-29-2012 Thread Starter
casey1999's Avatar
Re: I will ask, but if IRCC
DrB
The Hi Mod instructions state "do not over torque or threads will gall."
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 05:48 PM
Cast loc fittings IPR Gear & Maintenance 15 04-09-2012 10:03 PM
swage fittings TommyD Gear & Maintenance 2 12-14-2009 09:21 AM
Bronze Fittings gardeningal Pacific Seacraft 3 06-11-2009 09:41 PM
Thru Hull Fittings 1970Columbia34 Gear & Maintenance 3 02-17-2007 12:18 AM
