Servicing older lewmar winch - Page 2 - SailNet Community
post #11 of 20 Old 03-16-2016
Re: Servicing older lewmar winch
Originally Posted by captjcook View Post
Looks kill it has a head...push up from bottom?
Per the shop manual, it is designed to tap "DOWNWARD," with the winch standing securely on its base, with a clear area for the spindle to exit.
Between you, me, and the internet, I've tapped upward as well hoping to shock whatever binding was occurring enough to break the spindle bearing loose. No joy.
darkwater is offline
post #12 of 20 Old 03-16-2016
I was only able to find exploded parts view on link. The pin of course has serrations on the bottom, which indicates removal in that direction...as you have stated. An arbor press would be a better approach than tapping and risking peening. The winches I rebuilt came apart readily, I did not have the manual. I apologize for jumping to unfounded conclusions.
Jim
captjcook is offline
The Following User Says Thank You to captjcook For This Useful Post:
darkwater (03-16-2016)
post #13 of 20 Old 03-16-2016
A press has crossed my mind, as well. Possibly fashioning something out of c-clamps, and a bit of scrap metal, more likely. Thanks for giving it a go!
post #14 of 20 Old 03-24-2016
For posterity,
I solved my issue by soaking the pin in PB Blaster overnight, and buying a tap which was nearly as large as the pin itself, and a larger hammer. A few taps cleared it right out. Removed the lower gears, the bottom circlip, and retaining clip, then the rest came apart easily. De-greased with mineral spirits (overnight, because MAN was it rough,) then a rinse with diluted simple green. Mystery oil on the pawls, and a very light coat of lewmar grease on the components. Reassembled. They are just beautiful, now.
post #15 of 20 Old 03-24-2016
Well done!
post #16 of 20 Old 04-04-2016
Perhaps the lewmar winch manual volume 6 can be located at
http://www.international-boat-spares...%20VOL%206.pdf
The pdf file contains schematic diagrams of lewmar winches manufactured in 1980's.
Hisayasu Jin
Hisayasu is offline
post #17 of 20 Old 04-04-2016
This service manual, from the first page of this thread, also works.
Originally Posted by allene222 View Post
Here is a copy of the Lewmar service manual
Lemar Service Manual
There are also several older Lewmar winch diagrams here Winch Service Manuals
post #18 of 20 Old 08-30-2018
VERY OLD Lewmar winches have a circlip in the bottom of the main shaft , Tip it upside down peer in and below the central shaft gear there is a circlip like the one at the top . You might have to rotate the shaft to see it ! Prise it out and push the shaft from the bottom . Hey presto out it slides . Note there is also a tab washer below the circlip which need positioning with the tab in the shaft when re assembling Hope this info is not too late
Colin P is offline
post #19 of 20 Old 08-30-2018
Master Mariner
capta's Avatar
We have 22 older Lewmar winches on this boat from 2 speed 16's to electric 65st's. Using the diagrams and information on the Lewmar site, we have been able to open, clean, and lubricate every one of them.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #20 of 20 Old 08-31-2018
Originally Posted by darkwater View Post
For posterity,
Yes.
Older Lewmar 43 nst winch santana30RI Gear & Maintenance 6 12-11-2011 09:57 PM
lewmar standard 40 servicing pfirth Gear & Maintenance 6 04-10-2011 12:35 AM
older lewmar winch parts windancer1 Gear & Maintenance 2 09-11-2009 07:10 AM
Winch Maintenance - Help with Older Lewmar 40s CLucas Gear & Maintenance 3 02-03-2008 08:50 AM
It's Winch Servicing Time Tom Wood Gear and Maintenance Articles 0 10-17-2002 09:00 PM
