Batteries - Replacement - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 04-06-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
Re: Batteries - Replacement
I just replaced mine w/an Interstate DC27 Marine. Rated at 180 ah at 25a and told it had near half again the cycles at the next lowest (160ah/$117.) one @ 300...so 450 cycles!
Was listed at $150.75. I got another 10% off 'cause I bought a new batt for the vehicle at the same time. Pays ta ask for a discount! Will be my primary/only batt, as my Beta 20 only takes a couple hundred cranking amps ta start
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #12 of 16 Old 04-06-2013
Super Moderator
Maine Sail's Avatar
You are confusing Ah capacity and reserve capacity, they are not the same thing.
You have 180 minutes at 25A before the battery is dead or about 3 hours. Course you never want to completely kill the battery (a reserve capacity test takes the battery to 10.5V) so really you have about 1.5 hours at 25A.....
This is NOT the same as having a battery with 180Ah's. There is no such animal as a group 27 battery with 180Ah's or even 160Ah's for that matter. The average group 27 battery will have between 80 and 100Ah's of capacity at the 20 hour rate.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #13 of 16 Old 04-06-2013
deltaten's Avatar
Thanks for the clarification, MS
as read from the label;
Pro 27M ECL series
CCA625, MCA 845; assuming that's cranking amps?
RC 180
RCC 100
So.. the second number...RRC100 is the one to look at; 100 min @ 25A ???
Is the time and amps linear? IOW would that be the same as 1000 min @ 2.5A ??
My meager energy budget is only (proposed) to be near to 5a/hr while running lites are on and when anchoring and interior lites are on; perhaps 3a....LED's run "cheap", yanno I don't plan of running the monitor while away from shore power; but, w/associated electronics might run 4a.
Approx 7a divided into the 25a =3.57 X 100 min/60 works out to all but 6 hours before I enter trouble zone and need ta recharge.
Close? Did I get it near ta right?
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #14 of 16 Old 04-15-2013
I'm in the process of putting in 4 six volt batteries. I've used 2 in a series but looking for how to wire up 4. Know positive to negative. Do you hook up the actual feeds off positive and negative at the opposite ends of the chain. Also thinking about making it six if I can squeeze them in which I think will work. Have Balmar high output alternator. Later down the road want to add solar or wind
Thanks
Last Mango
Endeavour 38
Mobile AL
last mango is offline
post #15 of 16 Old 04-15-2013
chef2sail's Avatar
Thanks
Last Mango
Endeavour 38
Mobile AL
http://www.batteriesinaflash.com/wir...eries-parallel
Make sure you use the positive off one end of he bank and the negative off he other end of he bank to the panel so the batteries are used equally.
chucklesR likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
ďSailing is just the bottom line, like adding up the score in bridge. My real interest is in the tremendous game of life.Ē- Dennis Conner
chef2sail is online now
post #16 of 16 Old 04-16-2013
Glad I found Sailnet
Bene505's Avatar
I second MaineSail's point about getting a small solar panel.
On my first boat (Victory 21), I had a flexible solar panel strapped to the cabin top. Whenever I went for a weekly sail, the battery bank would be fully charged. The panel was small enough that I didn't need a charge controller.
And, IMHO, solar is a simple way to occasionally get the battery fully topped off.
Regards,
Brad
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
Tags
batteries , battery , gc2
Which 6v batteries? mtboat Gear & Maintenance 2 04-02-2011 04:42 AM
Li - Ion Batteries Raven38 Electrical Systems 1 05-29-2010 02:50 AM
AGM or GEL batteries? Kater Gear & Maintenance 20 03-12-2008 01:22 PM
Batteries tm3 Gear & Maintenance 20 12-08-2003 03:10 PM
AGM batteries has any one used them obiec Gear & Maintenance 4 04-04-2003 11:27 AM
