Spade rudders vs blue water passage making - Page 4 - SailNet Community
 14Likes
post #31 of 41 Old 09-11-2018
Re: Spade rudders vs blue water passage making
I'm really enjoying the discussion here guys. Please keep it up so I can learn from those with the expertise to provide good insight.
ImGary01 is offline
post #32 of 41 Old 09-11-2018 Thread Starter
One of None
deniseO30's Avatar
Originally Posted by FranklinGray View Post
I hate to bring an old thread back to life but would like to add something and also ask something.
My old boat, a Hunter 376 made in 1996 had a very low aspect rudder with a fat 6" composite post that insured it never stalled, however it was very unbalanced causing the boat to be hard to handle going fast and healed 20 degrees. I added 2" inches to the leading edge and everything changed. It was an awesome sailing boat with a perfectly balanced rudder. I could be healed over 20 degrees with 8 degrees of weather helm going 8 knots in the water and I could steer with 1 finger. I could let go of the wheel and it would stay put at 8 degrees of weather helm. The autopilot amp use dropped from 3-4 amps to 1-2 amps. I love spade rudders for having this ability to be balanced and I sailed mine for over 30,000 miles without any problems, including a 4,000 mile leg.
Now I am buying a large 55' Whitby with a long keel and a skeg hung rudder with 3 attachment points. I looked at Autopilots for sale that are recommended for the 54,000 lb boat and they burn about 7.5 amps. I'm like, darn, wish I could balance this rudder. But if I read this right, somebody on this thread took their skeg off and put on a balanced spade rudder. That has me going hmmmmmm. Should I consider such a thing?
On the other hand, I have read that the skeg rudder will track better. Is that true for quartering seas of say steep 10'?
Why are you buying a Whitby 55 that you obviously want to " fix" if you were so in love with a H376?
All because of a matter of 2 or 3 amp draw on the autopilot....
It's like comparing a ballerina to a sumo wrestler
capta and lillia28 like this.
My last project!
deniseO30 is offline
post #33 of 41 Old 09-11-2018
Did not say I like my Hunter better than the Whitby, just the balanced rudder. I doubt I will make a change to the rudder on the Whitby after thinking about it more because I think it would move the CLR forword making the boat unbalanced without the skeg.
edit: and it is not a difference of 2 or 3 amps, but 6 amps an hour, totaling 144 more amps a day just for the AP.
FranklinGray is offline
post #34 of 41 Old 09-11-2018 Thread Starter
One of None
deniseO30's Avatar
This? http://sailboatdata.com/viewrecord.asp?class_id=7509
Wouldn't it also have a genset and or larger battery Banks?
I'm seeing a modified fin keel and skeg Rudder I'm not seeing a full Keel or as you call that long keel, was that an option like on the W42?
And this
http://sailboatdata.com/viewrecord.asp?class_id=5333
My last project!
post #35 of 41 Old 09-11-2018
yes
post #36 of 41 Old 09-11-2018
Master Mariner
capta's Avatar
There would need to be a considerable amount of very expensive 'shoring up' of the internal rudder supports inside the boat, too.
We've got a 53' boat and if we want to (read; not being lazy), we can balance the rig rather easily, even with a skeg hung rudder and steer with one finger. Perhaps your problem with the old boat was sail trim, not the rudder?
Minnewaska likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #37 of 41 Old 09-11-2018
Perhaps you have never heard of the term Power Reaching.
post #38 of 41 Old 09-11-2018
Master Mariner
capta's Avatar
Actually, I haven't, so I went online and lo and behold every nautical or sailing glossary I found, including Wiki, apparently hadn't either.
If however, you are talking about overdriving a boat on a reach, dragging a big barn door to leeward, once again I might suggest you'd get just as much speed (perhaps more) and put your boat through a whole lot less stress if you could to learn to trim the helm out of the boat.
But of course, you obviously don't think so, therefore I'm just as obviously wasting my time responding to your reply.
If one day you get the opportunity to sail a hundred plus foot gaff schooner on a broad reach in a good breeze you could bring up the term 'power reach', but let me assure you it would just be an understatement!
capta is online now
post #39 of 41 Old 09-11-2018
outbound's Avatar
C is right. The key to speed is no drag from steering. Any steering input slows the boat regardless of rudder design. Overpowering by not reefing often slows the boat. Flat is fast as you’re not digging a hole in the water with your leeward side.
Go racing or follow your days work and see for your self if C hasn’t given you a good tip.
s/v Hippocampus
Outbound 46
outbound is offline
post #40 of 41 Old 09-11-2018 Thread Starter
One of None
deniseO30's Avatar
It's an older terminology https://www.yachtingworld.com/featur...trimming-64018
My last project!
Spade Rudders vs. Skeg Hung ehmanta General Discussion (sailing related) 33 10-13-2014 10:05 AM
Spade rudder - Ocean passage Minnewaska General Discussion (sailing related) 6 12-08-2010 08:17 AM
Making Passage w/o a Rudder wind_magic Seamanship & Navigation 60 07-16-2010 02:23 PM
Need advice on building spade rudders RobertKWFL Gear & Maintenance 4 05-07-2010 12:28 PM
First blue water passage south tahoedave Cruising & Liveaboard Forum 21 12-22-2006 04:58 PM
