Dinghy repair - SailNet Community
post #1 of 6 Old 11-07-2013 Thread Starter
Dinghy repair
Hey there, I have a 10ft Nissan hypalon dinghy, in the bottom there in a couple small hole on the bottom from wear and tear, it looks like the the wood floor is poking thru, best way to repair?
boatboy132 is offline
post #2 of 6 Old 11-07-2013
Siamese's Avatar
Re: Dinghy repair
Easy enough. Just get the hypalon patches, and the special glue, and patch it up. You're likely to find it all in a kit. First place I'd look is Defender.
You'll find instructions in the kit, and plenty more online, but basically, you cut a patch, rough up the area where you're going to apply the patch with sandpaper, apply the glue to both the boat and the patch, let it dry until no longer tacky, then press the patch solidly to the bottom. Done.
Siamese is offline
post #3 of 6 Old 11-08-2013
TQA
Bombay Explorer 44
TQA's Avatar
Re: Dinghy repair
I have found the 2 part glue that is being sold only to last about a month.
If you struggle to get the patches to stick then 3M 5200 will do the job.
TQA is online now
post #4 of 6 Old 11-08-2013
Master Mariner
capta's Avatar
Re: Dinghy repair
If they are small holes I have found nothing works better than super glue. The most important thing is to sand and clean the area very well, then cut a patch that is about 1/4 " larger than the hole and glue it on. Super glue dries almost instantly so you must get the patch in the right place first time. I've never had a super glue patch come off or leak.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #5 of 6 Old 11-08-2013
Re: Dinghy repair
+1
I used the Gorilla Super Glue suggested by another poster here, and it worked great. The key is definitely the sanding.
lowtide is offline
post #6 of 6 Old 11-08-2013
Re: Dinghy repair
All the patches on my dinghy that were applied by a "professional" using the so-called "proper" glue have come off, and within months. Every patch I've applied with two-part epoxy is still going strong. The secret is sanding the patch and area to be patched thoroughly so the glue has a rough surface to adhere to.
Vindö 50
copacabana is offline
Inflatable dinghy repair nestorph Gear & Maintenance 4 04-03-2013 11:23 AM
Dinghy Valve repair davidpm Gear & Maintenance 9 09-09-2012 08:43 PM
Repair of an inflatable dinghy pinayreefer General Discussion (sailing related) 9 08-30-2011 07:33 PM
Dinghy repair Kiltmadoc Gear & Maintenance 6 01-24-2011 09:09 PM
Dinghy repair adhesive? CellNav Gear & Maintenance 3 11-13-2008 10:36 PM
