Fiberglass blisters... Boat Leprosy?? - SailNet Community
 13Likes
post #1 of 17 Old 03-24-2014 Thread Starter
Closet Powerboater
MedSailor's Avatar
When cruising the yards and sales lots, some of the potential boats I want to buy are known to have blisters. I also know that blisters are common in 80s vintage boats because of various production issues. I was raised to believe that blisters are boat leprosy. Simmilar to wood rot, they will multiply and destroy the boat. If the boat's got blisters, walk away!
Recent reading on the subject reveals several articles from supposed experts saying that blisters are in fact no big deal. How can that be? If they're no big deal, then why does everyone worry about them so much?
What's the verdict? Cosmetic, or a fatal disease?
MedSailor
MedSailor is offline
post #2 of 17 Old 03-24-2014
RichH's Avatar
Re: Fiberglass blisters... Boat Leprosy??
Most boat blisters are hype, unless the hydrolysis, etc, is deep into and affects the structural roving layer of the laminate. Blisters affect mostly the cosmetic matting layer of a laminate structure, the matting is a 'cushion layer' so that the gelcoat remains stable during the full term / many years 'curing process' of the resins.
Hull Blisters on Boats and Yachts - by David Pascoe, Marine Surveyor
RichH is offline
post #3 of 17 Old 03-24-2014
kd3pc's Avatar
Most are cosmetic, some - especially if left alone for decades could allow water to infiltrate to the glass and then some repair would need to be done. As far as compromising the hull, I have never seen or heard of one failure.
too much ado about nothing. I have known several who spent $$$ to remove them, it is a labor intensive process with no guarantee that things will be better. A LOT of misinformation and "bar room" advice about them.
Speak with a surveyor or marine architect, if you were on Chesapeake, I would steer you towards Hartge Marine, they have quite a bit of experience with them. All the rest is hearsay, or worse.
kd3pc is offline
post #4 of 17 Old 03-24-2014
Lemonshirt's Avatar
Thanks for posting this question. Nearly every used boat advertisement boasts "no blisters". ..as if it really means something. While I dont have any personal experience, I can tell you about a friend's experience:
He left his brand new un-bottom painted powerboat in the water for several months. When he pulled it out, he noticed that the hull "had blistered" This was several years ago. He still owns and uses the boat regularly. ...though he doesnt leave it in the water for months on end anymore. His assessment is "its just cosmetic".
So if I was dropping big bucks on a boat, I'd want an unblistered hull. But if I was buying an old cheapee, I wouldnt be concerned. In fact, that might be the key to getting a real steal on a used boat.
Lemonshirt is offline
post #5 of 17 Old 03-24-2014
Send a message via Yahoo to dacap06
Boat pox? No, I don't think it is so serious, as others noted. All blisters are all repairable, even the serious ones (although they are a lot more trouble). Even better, most blisters don't need drastic measures to remedy as other noted previously. Dig out the compromised material, let the divots dry over the Winter, fill with a good epoxy-based material (e.g. thickened epoxy) and fair them, then protect the hull with a good epoxy barrier coat such as Interlux Interprotect 2000E or equivalent.
So long as the barrier coat is not compromised by grounding or collision with something underwater like a deadhead, no more problems. That worked for my '84 and many other boats of the era.
Regards,
Tom
T. P. Donnelly
I sold my sailboat and am no longer active on Sailnet
dacap06 is offline
post #6 of 17 Old 03-24-2014
Old enough to know better
Big issue is not that they destroy your boat but are very expensive to pay someone else to fix. Some boats like certain years of the Valiant it will be a reoccurring issue due to the flame retardant resin used. Others a grinding and barrier coat and you are better than ever.
If you like the boat and can do the work yourself go for it.
Sent from my ADR6425LVW using Tapatalk
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #7 of 17 Old 03-24-2014
This is just my 2 cents. A couple of years ago we pulled 4 soggy layers of blistered fiberglass off a friends hull. The bill for materials only was about 16K. You find many so called experts who say it isn't a problem but it is or will be, I have seen boats in the yard with sections of the hull split straight as an arrow up the main bulkhead seam. If done incorrectly patching blisters is like trying to paint over wood rot and saying its fixed. There are too many good boats out there why buy a rotting hunk of $hit.
barefootnavigator is offline
post #8 of 17 Old 03-24-2014
4 soggy layers of blistered fiberglass? What kind of boat was that? My experience with blisters has been the same as other posters - kind of a pain, but not really serious. Unless you pay somebody else to fix them.
sandy stone is offline
post #9 of 17 Old 03-24-2014
Dirt Free
boatpoker's Avatar
In 2986 surveys I have seen two boats so compromised by hydrolytic blisters that the hull integrity was degraded enough to be a safety issue. The vast majority I have seen have been cosmetic in nature. I have written my opinion in length on this topic in Osmosis Testing
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #10 of 17 Old 03-25-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
please believe him.. it makes the boats with a couple of blisters -much- cheaper for the rest of us who can do the work ourselves
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
Theory on cause of Fiberglass Hull Blisters travistowle Gear & Maintenance 119 10-31-2011 08:59 AM
fiberglass blisters lordpoltimore Gear & Maintenance 6 03-11-2010 06:30 PM
new boat blisters? bestfriend Gear & Maintenance 4 11-02-2006 01:35 PM
Boat with history of blisters gstraub Boat Review and Purchase Forum 12 12-02-2003 05:28 PM
blisters, boat hull that is nauticalrich Gear & Maintenance 2 11-22-2001 02:33 PM
