"Drain, Shock & fill water tanks" - SailNet Community
post #1 of 20 Old 04-06-2006 Thread Starter
I was going over my boat's owners' manual for spring recommisioning. One item was "Drain, Shock & fill water tanks".
What is "shock" supposed to mean here?
ddilman is offline
post #2 of 20 Old 04-06-2006
Shock is a term for Clorox get a couple of gallons pour it in the tank and top it up pump the mix through the hoses and save it if you want to scrub decks or something. You must use Clorox brand pure clorox the generic stuff has soaps in it and will give you the screamin willies. Clorox is a pure clorox and safe to use for water purification as well. I buy it at Sams three gallons cheep and the jugs I use to store water to rince off after diving.I do a couple of tabelspoons to a 30 gallon tank if the water is in question like all water in south Florida.
sailnaway is offline
post #3 of 20 Old 04-06-2006
Administrator
Jeff_H's Avatar
Shocking the tank is filling the water tank and drinking water system with a high mixture of water and a high concentration of clorine and leave it in the tank long enough to kill off bacteria. Generally I have heard somewhere between 1 to 2 cups of clorox per 10 gallons of capacity. The clorine solution is left for one to two days but should not be left too long as it might damage the plumbing.
You then go through a couple cycles where you empty the tank and refill it and emty it again. I have heard a variety of suggestions but that is what the Term 'shock' means.
Jeff_H is online now
post #4 of 20 Old 04-06-2006
I forgot to say the shock kills all bacteria and any slime that might have been growing in the tank. Health services give CLOROX to junkies because it kills AID'S. Also it will kill any thing that is alive including aquatic animals and man if you drink it. So make sure you pump it all out. I flush the system with a full tank after the shock is pumped out,that way you don't get the taste just clean water.
post #5 of 20 Old 04-06-2006 Thread Starter
Is shocking needed if I am not planning to use the water for drinking?
Is it ok to just flush the anti freeze as much as possible then fill up with water?
ddilman is offline
post #6 of 20 Old 04-07-2006
BTW, do not use the scented varieties of Clorox... and don't use the Clorox Ultra.
sailingdog is offline
post #7 of 20 Old 04-07-2006
dont use just clorox
I recall having this discussion with peggy hall (head lady).
if i recall she said not to leave clorox solution in the system for more than 24 hours as it degrades the rubber parts of the pumps.
after flushing the clorox solution through all hoses including the water heater (don't forget to remove aerators from the sinks they will get clogged with crud) you should fill the tanks with a vinegar solution to remove all traces of clorox. let sit 24 hrs then flush with fresh water.
i forgot what the dilution of clorox and vinegar was but try contacting her or better yet buy her book.
fair winds,
eric
kimberlite is offline
post #8 of 20 Old 04-08-2006
One thing not mentioned in this thread what your tanks are made of.
Shocking is ok with stainless, glass and plastic tanks. It should not be done on aluminum. Clorox (sodium hypochlorite) or any chlorine based agent is very agressive chemically.
In contact with un-coated aluminum it will start the formation of aluminum chloride scale (which will clog you filters), it will pit the surface of the aluminum, and if there are any minor welding flaws in the tank, it will take them from minor to major. While iodine based agents will do the job, they will leave a lingering "off" taste and quite a few folks are seriously allergic to iodine.
If you have aluminum tanks, you are better off using periodic steam cleaning through the inspection port and aggressive filtration.
Also, while shocking is effective on tanks other than aluminum, it is not enduring. Each tank fill will bring in small amounts of stuff you would rather not have in the tank.
A good filtration system pays for itself in good health, and if you can't filter, then a 15 minute rolling boil of any water you plan to consume is next best.
DynaMeme is offline
post #9 of 20 Old 04-08-2006
Dynameme makes good points all, especially the part about aluminum tanks... unfortunately, filtering the water as it is coming into the tanks isn't a viable option for most of us.
post #10 of 20 Old 04-08-2006
why cant you filter the incoming water
we use a very simple home depoot filter.
fair winds,
eric
Water "Drain" in Rudder? bacinmass Gear & Maintenance 11 11-23-2016 10:50 AM
1 1/2" water fill line--where to buy Bruce3966 General Discussion (sailing related) 4 09-28-2015 07:32 AM
To drain or not to drain dabnis Gear & Maintenance 3 09-17-2014 09:01 PM
Any good places to fill water tanks - Eastern LI Sound? Bene505 Long Island 10 04-23-2010 10:56 AM
Free places to fill water tanks - eastern Long Island Sound Bene505 General Discussion (sailing related) 0 04-01-2010 10:34 PM
