Scum in Fuel Tank - SailNet Community
post #1 of 14 Old 09-05-2014 Thread Starter
Crealock 37
sailak's Avatar
Dock
Scum in Fuel Tank
This is one of my fuel tanks. I have no idea if it has ever been opened or cleaned. The brown film you see easily wipes off.
Is this a normal amount of stuff? Nothing to worry about or an issue?
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #2 of 14 Old 09-05-2014
One of None
deniseO30's Avatar
Re: Scum in Fuel Tank
Normal as in any diesel tank that is "old" It's also the stuff that gets into the fuel when the boat starts it sloshing around like on a passage.. then it all goes right into.. yup.. the filter/s that everyone has many spares for when it happens.. uh huh.
Good for you having the willingness to get into it!
My last project!
deniseO30 is offline
post #3 of 14 Old 09-05-2014
Over Hill Sailing Club
smurphny's Avatar
That's a great photo of the inside of your tank. I don't know if there is any "normal." What is the tank material? It almost looks like it may be a bit of corrosion on 304 s.s.?? (rather than just fuel deposits). The tank looks like it is nicely constructed.
smurphny is offline
post #4 of 14 Old 09-05-2014
travlin-easy's Avatar
Diesel fuel is pretty much filthy, and because of this "stuff," which is nothing more than residue will accumulate in the tank. The big problem arises when water gets in the fuel - then the stuff soon becomes algae, clogs up lots of fuel injection parts and filters and the boat stops. There are fuel scrubbers available that take care of this, but they are expensive. Or, you can buy a bunch of spare filters, like all the cruisers do, and be prepared to change them frequently.
Good Luck,
Gary
travlin-easy is offline
post #5 of 14 Old 09-05-2014 Thread Starter
Crealock 37
sailak's Avatar
Dock
The tank is made of aluminum and is very well built (Pacific Seacraft has so far impressed me with the quality of their craftsmanship).
I started seeing just a tiny bit of particulate in the bowl on my Racors this year. What I found in this tank at the bottom was heavy, gritty, crumbly material.
I plan to open and clean the keel tank in the spring.
Thanks for the info.
Dale
S/V Elnora
sailak is offline
post #6 of 14 Old 09-05-2014
One of None
deniseO30's Avatar
Dale, is the tank removable? Older tanks tend to "seep" at the seams. Hope yours isn't!
My last project!
post #7 of 14 Old 09-05-2014 Thread Starter
Crealock 37
sailak's Avatar
Dock
Yes, they are removable. The one in the picture came out in about 15 minutes, hardest part was working the fill hose off the pipe.
Keel tank appears to be as easy to remove.
I don't believe they are leaking anywhere.
Dale
S/V Elnora
sailak is offline
post #8 of 14 Old 09-05-2014
pdqaltair's Avatar
Riddle me this:
If the AYBC is so thorough, and if shore-side above ground fuel tanks require internal inspection for leaks ~ 15 years (API 653), why are tank in a marine environment so difficult (with some exceptions) to inspect? Seems like a design flaw to me. I can see why gasoline scares folks.
Regarding corrosion, while we can't solve all problems, Some additives can stop internal corrosion dead (ValvTeck, Startron, and Stabil Diesel have tested well). Also, test the pH of the water you drain from the separator; we have seen some VERY low numbers from tanks with relatively benign levels of bacterial infection; polishing might keep it functional, but it won't remove that thin layer of acid from the bottom. Apparently inadvertent mixtures of even small amounts of ethanol (shared pipes or trucks) can cause some nasty conditions.
(Both of the cats I have owned had tanks in the bridge deck which were ventilated and drained to the water, so I felt OK about that. If I had an old tank in the bilge, not so much....)
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #9 of 14 Old 09-05-2014
smurphny's Avatar
+1 on the Star-tron. I use it in every tank fill and put it in any fuel stored for more than a few weeks. Star Tron Enzyme Fuel Treatment Diesel Additive
smurphny is offline
post #10 of 14 Old 09-06-2014
Bail out the diesel, put some detergent in there and some fresh water and scrub it until you can see you face in it. Dry it off and you will be OK.
Rockter is offline
Fuel tank for First 42 first42 Beneteau 16 12-26-2014 12:01 PM
Not just the fuel tank! 71Irwin32 Gear & Maintenance 9 10-18-2011 12:47 AM
Scum Floating on Coolant Hudsonian General Discussion (sailing related) 4 07-27-2010 08:48 PM
Fuel tank doalmo Gear & Maintenance 0 10-13-2004 03:39 PM
