Short tacking to windward is sailings heavy lifting. - Page 2 - SailNet Community
 27Likes
post #11 of 20 Old 09-24-2014
Barquito
Barquito's Avatar
Re: Short tacking to windward is sailings heavy lifting.
And without a self tacking headsail, some may be able to make some progress to windward under main alone. Then short tacking is beyond easy (physically anyway).
Valiant 32
Barquito is offline
post #12 of 20 Old 09-24-2014
no longer reading SailNet
Alex W's Avatar
The small %LP headsails that come with self-tacking rigs are also easy to tack in conventional ways.
If you are on a regular sloop and know you'll be short tacking up a narrow channel it can be helpful to swap out the genoa for a working jib. It makes the tacking easier, and on many boats allows you to point higher. Partially rolling up a genoa doesn't have the latter benefit.
Faster and TomMaine like this.
Alex W is offline
post #13 of 20 Old 09-24-2014
While generally I'm not enamoured with the current trends in new boats (layouts, styling, square doors/passageways - i.e. the 'Ikea' look- etc) I do like the way rigs are moving towards designs that are adequately powered up with non overlapping headsails. In our area where so often you're either heading straight upwind or DDW, I think such setups promote sailing over motoring when facing an upwind leg.
Faster is offline
post #14 of 20 Old 09-24-2014
Remember you're a womble
PaulinVictoria's Avatar
I enjoy tacking, especially singlehanded, its what sailing a sloop is all about. If you can't stand the heat....
Orange Crush
1974 C&C27 MkII
PaulinVictoria is online now
post #15 of 20 Old 09-24-2014
Jiminri's Avatar
The ability to easily short tack up rivers and creeks is one reason I have a cat-rigged sailboat. To tack I turn the wheel, to tack back I turn the wheel the other way....
FarCry and TomMaine like this.
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #16 of 20 Old 09-24-2014
drosymor's Avatar
Jiminri. I hope you are equally adept at relocating your beer: one swift graceful movement I hope.
Paul
Freedom 40
drosymor is offline
post #17 of 20 Old 09-24-2014
Jiminri's Avatar
Paul
Freedom 40
Paul,
Since the crew isn't occupied grinding winches (or doing anything else), I usually assign them the task of moving the beverage. However, if I'm sailing solo I just have to suck it up and turn the wheel one-handed.
Jim
West River, MD
Jiminri is offline
post #18 of 20 Old 09-25-2014
From my point of view, short tacking is in the same zip code as sailing on and off your mooring. A test of skill, forethought, and adventure that brightens my day. Turns the ordinary into fun.
Skywalker
bristol299bob likes this.
SkywalkerII is offline
post #19 of 20 Old 09-25-2014
Chastened
Ajax_MD's Avatar
Originally Posted by denverd0n View Post
Ditto.
And by doing so, if the day ever comes that you're in a tight channel and your motor fails... No problem. No panic. No need to call for help. You do this all the time. Easy-peasy.
It's less painful for me when the wind is up a bit, and I can use a jib smaller than my 170% or 155%.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #20 of 20 Old 09-25-2014
pdqaltair's Avatar
a. Atleast some of you most have started with a no-engine sloop, where short tacking was often a way of life, leaving harbor.
b. Though I hate the motor as much as the next guy, burning less than a tank each season is probably bad boat keeping. Inspite of all good practices (additives, vent filters, polishing), anything more than a year is just too long. Additionally, anything less that 50 hours per year is not going to shorten the life of the engine by one day; it will die from corrosion first. So there is NOTHING wrong with averaging 1-2 hours per week. It is not costing you anything... other than peace and quiet.
But yeah, an hour under power seems like a VERY long time. Ick.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
Tacking in heavy winds Jetexas Learning to Sail 8 12-18-2012 03:17 PM
Embed the Power of JOC Sailings Directly into Your Existing Website NewsReader News Feeds 0 01-18-2012 10:40 PM
1000 miles to windward - a short story GBurton General Discussion (sailing related) 18 01-03-2012 12:26 AM
New Dublin-Holyhead sailings (NewsWales) NewsReader News Feeds 0 09-29-2006 07:15 AM
Offbeat sailings this fall start from $489 (MSNBC) NewsReader News Feeds 0 09-06-2006 03:15 PM
