Knot failures - Page 3 - SailNet Community
 11Likes
post #21 of 25 Old 05-25-2015
Re: Knot failures
One of the first things I learned running bigger boats (65 feet) is that if you tie up with "yachty" cleat hitches, and then high winds and waves come in over night, you WILL be using the fire axe to get the lines off again. The last wrap with the hitch should never take any strain. If it does it can jam up and you can't get it off. An extra wrap or two before the hitch will prevent this.
Too small a line on a big cleat will slip off without extra wraps too.
capt jgwinks is offline
post #22 of 25 Old 05-25-2015 Thread Starter
davidpm's Avatar
Re: Knot failures
That is interesting too.
So you are saying that in pictures that the correct (ASA by the book) one will jamb so hard at high loads it will have to be cut off.
So where do you take your extra wraps. An extra turn around the base or and extra cross before the tuck or both. What did you find to be the minimum needed to prevent the problem you mentioned.
This implies that if you are tying up a normal 30' to 50' boat in expected storm conditions extra wraps of the type you are going to tell me might save your lines too.
davidpm is offline
post #23 of 25 Old 05-25-2015
Re: Knot failures
Nonsense, no way a proper cleat hitch will jam. The final hitch can only pull on itself. You coild pinch it up under the horn, if you have too many turns around the base.
Jeanneau 54DS
Minnewaska is offline
post #24 of 25 Old 05-25-2015
Not Finished Yet
RainDog's Avatar
I have no experience with large boats, but Grog would seem to agree with jgwinks on this one.
RainDog is offline
post #25 of 25 Old 05-25-2015
Over Hill Sailing Club
smurphny's Avatar
Re: Knot failures
A lot of it depends on the relative sizes of rope and cleat. I can see where a rope that is too big for the cleat will jam up, essentially losing the cleat in the knot. If a rope has to be jammed under the ear of the cleat, turning it into a jam cleat, then it's not surprising that a large diameter rope would be tighter than could be easily loosened by hand. I don't see how a line properly sized for the cleat can bind up if tied right. +1 on NOT taking any extra wrap on the base. If extra wraps are taken, they should be after the standard first hitches.
I don't know how many of you have been to Green Cove Springs, where I keep my boat, but the pier is an old WWII Navy dock with GIGANTIC cleats (I mean like 3' long) that are almost humorous to use with small boats. Talk about having to take extra wraps!
smurphny is offline
Rudder Failures smackdaddy General Discussion (sailing related) 38 10-25-2014 03:11 PM
Inflatable PFD Failures? smackdaddy General Discussion (sailing related) 81 06-25-2014 02:55 PM
Rigging Failures D9MCW General Discussion (sailing related) 19 03-19-2014 07:02 PM
Why George Bush's Failures Still Matter. ericb760 Politics, Current Affairs, Guns & HOT Topics 24 03-09-2014 03:03 PM
Hose clamp failures? downeast450 General Discussion (sailing related) 5 12-23-2009 10:05 PM
