Cal25 rudder shaft - Page 2 - SailNet Community
post #11 of 13 Old 07-10-2015
JimsCAL's Avatar
Re: Cal25 rudder shaft
A temporary fix would be to cut some thin plastic sheet (like from a milk bottle) and insert it into the gap between the shaft and rudder tube.
JimsCAL is online now
post #12 of 13 Old 07-10-2015
Lake Superior Sailor's Avatar
Jim's Cal, How much slop in yours? and has it been repaired? I have a Cal 28 1967 and it has a 1/8 inch slop.I have had it apart to check the tube and shaft and found no real wear....Why fix what isn't broke?....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
The Following User Says Thank You to Lake Superior Sailor For This Useful Post:
tom_beckstedt (07-13-2015)
post #13 of 13 Old 07-12-2015
JimsCAL's Avatar
There is virtually no slop in my current Cal 33, but I did that trick on my previous boat (Cal 9.2). Worked well.
Ideally you will have almost no slop and there is no addition friction preventing the rudder from turning.
Rudder Shaft seahorse 2 Islander 0 04-11-2015 07:38 PM
CS-36T rudder shaft soyuz General Discussion (sailing related) 0 07-03-2014 12:24 PM
rudder , shaft and engine out, then what? GaiaOrion Gear & Maintenance 2 02-03-2014 11:08 PM
Rudder Shaft Lube chs1517 Gear & Maintenance 4 11-15-2009 11:59 AM
Dufour 32 Rudder shaft dufour32 Dufour 1 08-10-2009 05:37 PM
