Ooohhooookkaaayy, you think you've tried some greasy sailing?? - Page 2 - SailNet Community
 4Likes
post #11 of 24 Old 08-19-2015
georgemci102a2's Avatar
Re: Ooohhooookkaaayy, you think you've tried some greasy sailing??
I'm thinking he has no problems sailing into a slip
Pacific Seacraft Flicka 20/Jack Helms 24
georgemci102a2 is offline
post #12 of 24 Old 08-20-2015
Here is a link to an article in the local newspaper about this video Telemarksavisa - I all verden, kan dette gå bra?
Google translate for those who don't read Norwegian https://translate.google.no/translat...%2F5-50-108899
knuterikt is offline
post #13 of 24 Old 08-20-2015
jppp's Avatar
C'mon, no spinnaker?
jephotog and SHNOOL like this.
1985 C&C 35 MK 3 #150
LIS
jppp is offline
post #14 of 24 Old 08-20-2015
Freedom isn't free
Dock
Yeah that video is just begging for a solo symmetrical spinnaker launch...
Kudos to the skipper. Pretty boat too.
Freedom, a 1983 C&C 32 sailing Smith Mountain Lake, VA
SHNOOL is offline
post #15 of 24 Old 08-20-2015
Once known as Hartley18
Classic30's Avatar
Dock
Great video.
Back in my dinghy-sailing days on a local lake, I used to love doing that, weaving in and out of the various bird-nesting rocks and islands scattered around.. and scaring the tripe out of people casually strolling past arm-in-arm (the last thing they expected to see was a 14' dinghy creeping silently along behind them only inches from the path!). ..but I never had as big a play-ground as they do in that video.
It is REALLY GREAT FUN and a real test of skill and nerve, but you do have to have worked out a course beforehand, have a good handle on wind direction (and a gentle breeze) and be really, really comfortable with your boat and the way it handles. To do this at all you also need to be sailing a shallow-draft dinghy with a good range of sail movement and quick-raising centreboard and rudder. Fairly vertical sides also help by making it easy to see your waterline all around. The secret is to keep the boat moving always.. if ever you stop, you're history.
I was doing it in an Impulse dinghy - a Laser dinghy would be okay also, but the curved sides make it harder to see where you're going.
Anyway, if you're a dinghy-sailer and get a chance in your area - don't knock it till you try it!!
Classic30 is offline
post #16 of 24 Old 08-20-2015
scratchee's Avatar
I would need rub rails made of tire tread...
scratchee is online now
post #17 of 24 Old 08-20-2015
Classic30's Avatar
Dock
Actually, no.. it's not the rub rails that would hit first but your chines. Very, very few rocks and channel sides are precisely vertical (they all slope outwards at varying degrees) and it's for that reason that this 'rock dodging' is even possible.
As I mentioned and as the video shows, the key is to keep moving. Your bow wave (even a small one) reflects off of the rocks and helps keep you centered in the channel. If you stop (usually because you've misjudged the depth and grounded the centreboard!) you're in big trouble and might even find you're now wedged in and can't get going again: a somewhat embarrassing predicament, to say the least.
..so the last thing you want is rub rails made of tire tread.
post #18 of 24 Old 08-20-2015
Classic30's Avatar
Dock
FWIW: There's at least one "scenic tour by powerboat" company in these parts that makes a buck out of roaring through a narrow gap between rock faces at +30kts for the thrill of their passengers. That only works because the pressure of the bow wave causes the boat to ride up and through a seemingly far-too-tight passage.
Same concept, different speed.
post #19 of 24 Old 08-20-2015
HANUMAN
RobGallagher's Avatar
Rockstar!
RobGallagher is online now
post #20 of 24 Old 08-21-2015
Originally Posted by justified View Post
And a new meaning of Local knowledge and Restricted Maneuverability.
In the immortal words of Oliver Optic, "Any fellow knows just
where the bottom is, but he don't always know how far it is from the top."
The only dumb question is the one that you didn't ask because you thought it would make you look dumb.
Atlas is offline
Cleaning nasty greasy bilges? Zogumwesterly Gear & Maintenance 32 08-25-2009 12:43 PM
2006 US National Sailing Team Named - US SAILING News @ ISAF - Sailing.org NewsReader News Feeds 0 04-20-2006 07:18 AM
USA. US SAILING names 2006 US National Sailing Team @ BYM Sailing News NewsReader News Feeds 0 04-20-2006 03:16 AM
