Standing rigging question - SailNet Community
 2Likes
post #1 of 18 Old 09-17-2015 Thread Starter
rbyham's Avatar
I am about to change out original 1978 rigging on my bombay pilot 31. I will be using a rigger to get the work done. But before we start I want to make sure we have a solid foundation in terms of chain plates and mast base. While both of those issues look good to my eye I still have a question. The current rigging shows all connections bottomed out at the turnbuckles. In other words there is no room left to tighten. So the new rigging will have to be made shorter in order to get rigging tight. But what would cause rigging to bottom out? Does this point to a potential mast or chainplate issue or is it common for stays to lengthen/stretch from use and age? if so over time can it sufficiently stretch as to bottom out any adjustment?
The two best days of a boater's life... The day he buys it and every day he SAILS it.
rbyham is offline
post #2 of 18 Old 09-17-2015
RichH's Avatar
Re: Standing rigging question
Some reasons for turnbuckles to be bottomed out:
1. Mast butt / step (either deck stepped or keel stepped) has corroded away. (Mast no longer at original length dimension).
2. Mast was replaced, not rigging.
3. Rigging was often stressed past the 'yield' value of the material. Rigging is stretched.
RichH is offline
post #3 of 18 Old 09-17-2015
It could also be that the chainplates have been pulled out of the deck. Honestly on a 30+ year old rig I would probably pull everything and at a minimum do some non-destructive testing. It's likely not much more to just replace everything though.
Greg
Stumble is offline
post #4 of 18 Old 09-17-2015
Otter
DivingOtter's Avatar
Rich said it. You need to know why the rigging settled. Hopefully it's as simple as aged, stretched rigging that was just tuned over time.
DivingOtter is offline
post #5 of 18 Old 09-17-2015
krisscross's Avatar
If it's a deck stepped mast, you may also have a deck sag (entire deck, not just cabin top), which lowers the mast height. I would look very closely at your mast support structure. You have to properly transfer the load from under the mast to keel.
Plato
krisscross is online now
post #6 of 18 Old 09-17-2015
Tanski's Avatar
No expert by an means but what Krisscross says makes sense. Other wise that is a lot of "stretch" distance that would have been taken up, if it were chainplates I think you would notice they had pulled by that amount.
We have to be talking inches here, not just a few fractions.
And the fact that it is all the turnbuckles that are bottomed out?
Needs to be looked at, sounds kind of serious to me thinking about the whole picture.
Tanski is offline
post #7 of 18 Old 09-17-2015
Otter
Out of curiosity, why was the original rigging standing for so long? Has the mast been dropped for storage or maintenance? Has it been in storage? Has the rigging been inspected? I'm hoping it's something simple.
post #8 of 18 Old 09-17-2015
RichH's Avatar
For ALL the turnbuckles to be 'bottomed', Id look carefully for a single cause: mast butt corroded away, mast step plate corroded away, sagging mast base support (sagging coach roof, deformed compression post, or keel/shoe) to have changed dimensions. Forensically, It would be pretty rare for all the standing rigging to have 'yielded' (stretched) that 'uniformly'; hence, suggestive of a singular cause.
davidpm and Capt Len like this.
RichH is offline
post #9 of 18 Old 09-17-2015
Originally Posted by RichH View Post
For ALL the turnbuckles to be 'bottomed', I'd look carefully for a single cause:
Or they were simply built the wrong length? Remember this the marine industry that is famously unable to do much of anything consistently right. Easily could have come from the factory with too long wire...
When you write "all" do you include the stays, or only the shrouds? A shrinking mast or failing mast step will affect the stays less than the shrouds (by about 30%). Failing chain plates will not affect the stays at all.
Pretty simple to see mast or chainplates issues of this magnitude.
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
post #10 of 18 Old 09-17-2015
RichH's Avatar
For all or almost all turnbuckles to be bottomed out, on a boat that size and assuming 3" (76mm) turnbuckles (or 1.5" / 38mm displacement from the 'middle') that 38mm deflection of 'permanent stretch' would translate to (from http://www.riggingandsails.com/pdf/selden-tuning.pdf P29) 5% strain per millimeter change (elongation) per each 2 meters of wire length ....... Approx./SWAG = 5 X 38 = 190% stress .... which is functionally impossible; therefore, there most likely has been a dimensional change in the 'base structure' that is supporting that wire rigging and/or mast.
RichH is offline
standing rigging question Faith25 Cal 6 08-30-2013 02:03 AM
Terminology question about standing rigging johnnyandjebus General Discussion (sailing related) 5 03-09-2013 06:30 AM
Standing rigging question brak Gear & Maintenance 25 05-19-2008 09:55 AM
Standing Rigging Question sailingaway92252 Gear & Maintenance 2 04-17-2007 06:00 AM
Standing Rigging Question gwp Gear & Maintenance 5 01-23-2004 02:45 AM
