Thoughts on this idea to try and change seacock on trailer - SailNet Community
 1Likes
  • 1 Post By Bruce3966
post #1 of 9 Old 09-27-2015 Thread Starter
So I am changing all seacocks (currently has old gate valves) and the head intake thru-hull fitting is about a third of the way under the wood on the trailer (photo attached). Since the side wood cradles only help stabilize the boat I was thinking first of just cutting out a section of the wood and then I changed my mind and I am now thinking about taking my right angle drill and just drilling a 1 1/2" hole right under the thru-hull with of course stopping about an 1/8" before hitting the hull and finish by using a knife to carve out the rest of the wood. The part that sucks about this is trying to drill a hole with about a 1/3 missing in that cut is hard.
I have to change both pieces of wood on the trailer and carpet them anyway next year after I launch. I cannot take the chance in keeping this gate valve in for a summer sailing. If anybody has a better idea I would love to hear it.
1985 O'Day 26'
I spent all my money on booze, boats and broads. And the rest of it, I wasted. - Elmore Leonard
Bruce3966 is offline
post #2 of 9 Old 09-27-2015
Re: Thoughts on this idea to try and change seacock on trailer
That doesn't look like much wood n the way. Use a chisel...carefully.
Why is the carpet on the bottom of the bunks?
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
post #3 of 9 Old 09-27-2015 Thread Starter
All my boats (all motor) through out my life have had indoor/outdoor carpet on the wood. I would never have a boat sit on raw wood. What do you or others use if not carpet?
Sent from my iPhone using Tapatalk
1985 O'Day 26'
post #4 of 9 Old 09-27-2015 Thread Starter
Hey thanks. No idea why I didn't think of using a chisel. I did drill half way through with my right angle drill and just used a BF screwdriver and knocked out the rest in 5 min.
1985 O'Day 26'
post #5 of 9 Old 09-27-2015
Master Mariner
capta's Avatar
Couldn't you just jack up the boat enough to do the switch out and not cut anything?
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #6 of 9 Old 09-27-2015 Thread Starter
No immediate way to jack it up but I'm all set. Have the old thru-hull out already. I'm interested in hearing more from others about carpet on the trailer bunks.
1985 O'Day 26'
post #7 of 9 Old 09-28-2015
Maybe I am seeing this wrong, but in your photo it looks like the boat is resting directly on the wood, while the carpet is on the bottom of the bunks.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #8 of 9 Old 09-28-2015 Thread Starter
That it is in some areas only due to another one of the PO's sad maintenance items.
Capt Len likes this.
1985 O'Day 26'
post #9 of 9 Old 09-28-2015
Small boat? Use a car jack with suitable padding/blocking to just raise the hull off that part of the trailer, enough so you can just use the hole saw without worries. Or some cedar shakes, or other wedges, to just lift that part of the hull another inch.
hellosailor is offline
Trailer sailor - Fl Keys - where to leave tow vehicle & trailer cdy General Discussion (sailing related) 3 09-06-2015 05:52 PM
Can you ID this seacock? jsaronson Gear & Maintenance 15 01-26-2014 09:23 PM
changing tire on trailer with boat on trailer johnnyandjebus General Discussion (sailing related) 14 07-01-2012 06:09 PM
Any thoughts/criticisms on my repair idea? philo13 Gear & Maintenance 2 06-07-2009 12:53 AM
I have no idea how to find the right trailer for my boat! natejount Boat Review and Purchase Forum 7 12-19-2003 03:23 AM
