Captain Tolley's Crack Cure - SailNet Community
 2Likes
  • 2 Post By outbound
post #1 of 8 Old 10-05-2015 Thread Starter
Has anybody used this for spider cracks and if so, thoughts?
I have heard this works pretty good for any small crack etc.
1985 O'Day 26'
I spent all my money on booze, boats and broads. And the rest of it, I wasted. - Elmore Leonard
Bruce3966 is offline
post #2 of 8 Old 10-05-2015
Re: Captain Tolley's Crack Cure
It works on sealing clean cracks, spider cracks if old may be filled with all manner of dirt and debris. It may be almost impossible to clean out spider cracks enough for trolley's to do more than just stick to the crude.
Ulladh is online now
post #3 of 8 Old 10-05-2015
One of my previous boats had a crack in a cockpit seat that had something squirted into it. There was a half empty bottle of Tolleys on board so I assume that was what was in the crack. Didn't appear to have worked at all. Crack was still open and the core was wet, but of course if was that bad before he had tried to fix it, nothing would have worked short of replacing the core and gassing over the crack, which I eventually did.
capt jgwinks is offline
post #4 of 8 Old 10-05-2015
jsaronson's Avatar
used it successfully on small leaks.
Atlantis
Hylas 44
Annapolis
jsaronson is offline
post #5 of 8 Old 10-05-2015
Sea's The Day Charters
Captain Tolley's is the best!!!
jlaskowsky73 is offline
post #6 of 8 Old 10-05-2015
outbound's Avatar
Used it on a leak where chainplates pierced the deck. Plus/minus. Smeared vasoline over the spot. Leak gone. 5cent fix that worked. If leak comes back will blow another 5 cents. Woo hoo big spender.
Atlas and Johnniegee like this.
s/v Hippocampus
Outbound 46
outbound is offline
post #7 of 8 Old 10-06-2015 Thread Starter
I ordered an 8oz bottle. I'll just squirt it over the entire boat.
1985 O'Day 26'
post #8 of 8 Old 10-06-2015
I used this on my leaky windows, and it worked great. It seems to flex slightly, and leaky windows are now dry for two years. I added a little, multiple times.
Sent from my LG-D852 using Tapatalk
apneab is offline
Cure For Seasickness? JulieMor Cruising and Sailing with Children 26 12-24-2012 08:31 AM
Epoxy won't cure. Help! kwaltersmi Gear & Maintenance 13 09-14-2011 02:18 AM
Sailing for a cure Slayer General Discussion (sailing related) 0 08-13-2008 12:06 AM
Sea Sickness - Cure? Tucks Learning to Sail 87 03-31-2008 08:16 PM
Fiberglass cure time wallybygolly Gear & Maintenance 7 02-13-2007 03:14 PM
