Motor choice for sirius 21' - SailNet Community
post #1 of 3 Old 10-26-2015 Thread Starter
From a previous post, I passed on the oday 23 with the two piece mast modification. It just seemed liked it would be inviting trouble.
Instead I bought a sirius 21, which was in much better shape, but did not have a motor. It does have a motor bracket on the transom. Because of that I think I can go with a "regular" shaft outboard as oppose to the long shaft. Just thought I would check in with folks here to see if there were any Sirius owner or anyone else with an opinion. Thanks Chris
csalatti is offline
post #2 of 3 Old 10-26-2015
TQA
Bombay Explorer 44
TQA's Avatar
Re: Motor choice for sirius 21'
Nope get a long shaft. Then the prop stays in the water [ mostly ] if there is some sea running.
TQA is offline
post #3 of 3 Old 10-27-2015
I don't know about the physiology of the Sirius 21, but I don't think a shorter shaft is necessarilly out of question. A few questions to answer before you dismiss the shorty. How low to the water is your transom? Would a short shaft sit deep with the bracket down? Will you be able to get the prop out of the water with a long shaft? Can you reach the controls? Be sure to consider the water intake.
DonScribner is offline
Sirius 28 information? Anyone? kjmactavish Boat Review and Purchase Forum 7 07-17-2010 02:36 AM
Sirius Weather Module andantesail Pacific Seacraft 8 04-05-2010 09:08 AM
Raymarine: Sirius Reciever artbyjody Gear & Maintenance 25 10-29-2008 07:33 AM
Raymarine Sirius Weather jr438234606 Gear & Maintenance 19 07-10-2007 12:05 AM
Satellite Radio - XM, Sirius? prussell Cruising & Liveaboard Forum 5 06-07-2003 07:49 AM
