SailNet Community (https://www.sailnet.com/forums/)
-   General Discussion (sailing related) (https://www.sailnet.com/forums/general-discussion-sailing-related/)
-   -   Watermaker plans (https://www.sailnet.com/forums/general-discussion-sailing-related/227674-watermaker-plans.html)
Don L 11-17-2015 11:42 AM
Watermaker plans
Who has a fairly recent set of water maker plans with component part numbers and websites of suppliers of them that they are willing to share?
Don L 11-18-2015 10:13 AM
Re: Watermaker plans
No one? What if I say that AC has it and WG doesn't?
Barquito 11-18-2015 11:04 AM
I'm sure you have come across this info, but, here is a thread that lists some suppliers:
https://www.sailnet.com/forums/gear-m...ker-plans.html
capta 11-18-2015 11:23 AM
I built my 32+ gph, watermaker from scratch, for right around 2k.
First thing I did was locate a pump. They're by far the most expensive item. It took about two months of dedicated searching, but I finally found virtually new one at a very good price.
Then I went online and found half a dozen diagrams from various manufacturers and consolidated their best features into the system I wanted to build. Some specialized parts I got from Cruise RO Water & Power, others I searched out myself, including the membrane.
A little tweaking over the years and I'm really happy with my 2k system, and the other $3500 was well spent otherwheres.
Rich with Cruise RO Water is incredibly helpful even if you aren't a customer, should you need help. He can also supply the specialized parts that might be better bought from a company that has already researched their suitability for this purpose.
Rocky Mountain Breeze 11-18-2015 09:24 PM
If you are going to drive it with the engine a small triplex pump and one of the RO filters listed in the link above should work great. Your chief problem will probably be limiting the pressure produced by the pump.
misfits 11-19-2015 09:58 AM
Three or four years ago GOB had two issues dedicated to DIY water makers with parts list.
RichH 11-19-2015 10:12 AM
Do consider to follow Leo Lichtfeld's description and plans, as they are spot on.
For long term cruising; and for commentary for a 6 year upgrade to my comments in that previous thread, consider .....
A BRONZE head high pressure pump.....
Carry extra high pressure gages, those stainless steel gages for high pressure sea water will only last 3-4 years in seawater.
Id also recommend that if you do DIY build, you also download Filmtec's Operation and Maintenance manual so that you can 'restore/regenerate' the membrane when bio-fouled and needing sanitization. Such chemicals (peracetic acid + hydrogen peroxide, and sodium hydroxide) can be 'dangerous' if you dont have the chemical 'safety' expertise. A commercial source of the peracetic/H202 is found under the brand name 'Minncare' and such 'cleaning' needs chemical 'dip sticks' to be sure/verify that this chemical is flushed entirely after sanitization.
eg.: http://inaqua.de/Prod/nano/pdf_en/02.1_Cleaning.pdf
Placing the highpressure pump ON the engine, needs a very strong mounting, one that can withstand the constant engine vibration. Without such consideration, your 'mounting' will be quite vulnerable to metal fatigue.
I would also recommend an automatic belt tensioner for an engine mounted pump system (McMaster-Carr, etc.).
I would also strong suggest that the chosen water feed pump to the high pressure pump be rated for 'continuous duty' service as if the pressure pump is not continually supplied with water .... it will instantly burn out and destroy itself.
Most of the components can be found on eBay, etc. if youre patient. Typically most of the components will be found there during wintertime when 'pressure washers' arent being used.
Brent Swain 11-19-2015 02:02 PM
My book has plans and instructions for building a 540 gallon per day watermaker for under $1,000. Mine works fine; has for years .
Don L 11-19-2015 04:18 PM
So be a man and post it instead of trying to shake me down.
Empty Pockets 11-19-2015 05:25 PM
Be a man and pony up for the man's work, instead of asking someone to do it all for you for free...
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
