Oily bilge water - SailNet Community
post #1 of 10 Old 02-23-2016 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
Oily bilge water
Would it be a no no to dump oily bilge water in the used oil recycle drum at the Marina? If so how can I get rid of it?
brokesailor is offline
post #2 of 10 Old 02-23-2016
Old as Dirt!
svHyLyte's Avatar
Re: Oily bilge water
Pick up a couple of Oil Absorbent Pads and float them in the container/bucket for a few days. They will suck up the oil and can then be discarded and the water simply poured out.
FWIW...
svHyLyte is offline
post #3 of 10 Old 02-23-2016
deltaten's Avatar
Send a message via Yahoo to deltaten
Quantity of water? How much oil?
Last time I hadda do it, I bucketed it into a 5 gal container and let it settle for some time. Once all the oil was surfaced, I used a specific , IDK which?, oil absorbent pad/engine diaper to soak the oil from the surface. Dumped the water in the gravel driveway (at home) and the diaper went into the dumpster.
Unless you had a catastrophic oil loss, should only be a couple tablespoons full. Just that it's spread around so much, like that quart of paint I dropped from step ladder! Looke d like a helluva lot more'n a qt.
Ya could always ask the Marina operator about putting it in the recycle tub
HyLyte beat me to it
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #4 of 10 Old 02-23-2016
Broad Reachin'
kwaltersmi's Avatar
I'd check with a your local municipalities (township, county). Many have oil and hazardous waste recycling/disposal offered for free. I used our county's disposal when I changed out my diesel tank last summer.
Catalina 34
kwaltersmi is offline
post #5 of 10 Old 02-23-2016
centerline's Avatar
the rule for oil in dumpsters is, as long as its absorbed into something so it will not leech out, it can be placed in the dumpster... drained oil filters can go in the dumpster, used oil-sorb pads and rags can go in as long as they wont drip oil out.... oil, oily water, and antifreeze goes into a container and sets on the curb for the recycle people to pick up.
Cal 34-III, Nu Liberte
Portland, Oregon
it seems as if there is a growing population of people in the world, who dont have sense enough to recognize a senseless idea when it enters their mind...
When you are dead, you dont know you are dead so it doesnt bother you, but it can be really difficult for others...
its the same when you are stupid....
centerline is offline
post #6 of 10 Old 02-24-2016
Look for 3M oil absorb pads on Amazon, not a marine supplier. I ended up with a lifetime supply for what I usually spent per year, buying them one at a time at the marina.
Jeanneau 54DS
Minnewaska is offline
post #7 of 10 Old 02-24-2016
NAPA has good prices on then as well.
Shockwave is offline
post #8 of 10 Old 02-24-2016
pdqaltair's Avatar
Depends on the recycle center. Many forbid water or have a separate tank.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #9 of 10 Old 02-24-2016
I used about three rolls of paper towels once, on a newly-purchased boat I was to help deliver. Oil floats, so mostly does the Charmin, and we got the bilge water, and then the bilge, surprisingly clean. It was just accumulated oil, no leak once we cleaned up.
nolatom is offline
post #10 of 10 Old 02-24-2016
snake charmer, cat herder
zeehag's Avatar
Send a message via Yahoo to zeehag Send a message via Skype™ to zeehag
buy a buncha boat engine diapers n soak it up. they will not suck up water, only the oil. that makes life a whole lot better.
i had to do this a few million times already, so i know they work. buy extras.
formosa 41, cruising tropics
zeehag is online now
bilge water captain jack Gear & Maintenance 15 12-17-2013 12:06 AM
What to do with bilge water? dvuyxx Gear & Maintenance 34 07-17-2011 11:38 AM
Bilge water BayDancer Catalina 1 07-08-2006 11:31 AM
Where does bilge water come from? chris1514 Gear & Maintenance 8 07-27-2003 08:51 AM
Oily Bilge dscottl Gear & Maintenance 3 06-12-2002 12:29 AM
