Turbo diesels - Page 5 - SailNet Community
 3Likes
post #41 of 47 Old 03-14-2016
blt2ski's Avatar
Re: Turbo diesels
After I finished, idling a diesel is actually not good for them. As raw diesel will getinto the cylinder walls, go down into the oil, and cause issues. You do not normally get the motor up to a decent running temp such that it will last either. The ONLY reason you see big rigs idle, is so the driver can stay warm in the cab. A lot are now running auxiliary diesel gensets to run a furnace, etc inside the sleeper cabs. I recall seeing somewhere, an hour of idling is like 8-12 hours of running full throttle down the road from an engine wear stand point.
I can not personally recommend you idle ANY motor be it gas, diesel, propane or what ever for very long. Then you are hurting yourself more than helping. Most newer rigs in the OM will state do not idle etc.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #42 of 47 Old 03-14-2016 Thread Starter
outbound's Avatar
Re: Turbo diesels
Great posts
So another habit bits the dust. Our routine has been turn on engine, get boat ready, leave. Dock/moor/anchor turn it off. In both cases ~5 minutes of running with no load. Was told diesels like to run under load and don't with no load.
Is running the engine for a few minutes with no load at start up and shut down really bad for it?
s/v Hippocampus
Outbound 46
outbound is online now
post #43 of 47 Old 03-14-2016
blt2ski's Avatar
Re: Turbo diesels
I personally prefer to idle as little as possible.
As soon as I am tied to the dock, off goes the motor. If I have race crew/kids on board, motor is off before they tie the boat up, ie as soon as they are off the boat, and have line around the cleats etc. Altho my 6500 lb boat is probably easier to handle than a 20-40K lb 46' cruising boat! so a bit more idle may be needed with two peeps onboard, or in my case if alone, Idle until I get things tied up, then turn off.
Turn on, untie take.
If really cold, put the trans in neutral, turn up the motor to say 1200-1500 rpm vs idle at 600-800.
Newer motors like to be idled as little as possible.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #44 of 47 Old 03-14-2016
TQA
Bombay Explorer 44
TQA's Avatar
Re: Turbo diesels
Wow lots of stuff in this thread that contradicts what I had always thought true.
Most yachts now come with turbos. I know that there are some yachts supplied with Turbo Diesels but I had always thought they were in a minority.
Turbo diesels can only idle if the turbo fails. I used to carry out a series demonstrations for my motor vehicle students which included running with a seized turbo. Yup lots of smoke but it still produced about half rated power at max revs. A modern turbo diesel with a engine management system will have a limp home mode which it will enter if the turbo fails. You will get more than idle but not full revs.
Injectors can only be stored for a short time. I don't know if this applies to the latest common rail injectors but the older type is sprayed with WD 40 and kept in a Ziplock back they keep just about forever.
Shell Rotella is dead dino oil. Well I think that depends on exactly WHICH Rotella we are taliking about eg. Shell Rotella® T5 is a Synthetic Blend Heavy Duty Engine Oil
TQA is offline
post #45 of 47 Old 03-15-2016 Thread Starter
outbound's Avatar
Re: Turbo diesels
I'm with you TQA. Finding out a lot I thought was gospel just ain't true anymore. In the road vehicles have been using full synthetic for years now but in the boat use Rotella for both genset and engine. Figure it's more important to change oils frequently in the boat even when hours don't demand it just to get acids and impurities out as don't want them sitting in those key devices. Thought the extra expense of full synthetics not worth it. Haven't been doing just the spring and fall changes for some years now.
Still know I get better mpg with full synthetics in road vehicles. Wonder how this translates to boat engines?
s/v Hippocampus
Outbound 46
post #46 of 47 Old 03-15-2016
TQA
Bombay Explorer 44
TQA's Avatar
Re: Turbo diesels
I was being ironic.
TQA is offline
post #47 of 47 Old 03-15-2016 Thread Starter
outbound's Avatar
Re: Turbo diesels
So I'm confused. Please be specific about what irony.
For now will believe what yanmar tells me.
s/v Hippocampus
Outbound 46
Turbo wastegate sticks Minnewaska Gear & Maintenance 2 09-07-2015 08:35 PM
Turbo temps Minnewaska Gear & Maintenance 1 10-01-2012 01:29 PM
Marine Diesels vs Truck Diesels casey1999 Diesel 25 10-27-2011 10:58 PM
Turbo Diesels tdw Gear & Maintenance 26 02-26-2010 10:30 PM
Turbo Diesels Tom Wood Gear and Maintenance Articles 0 10-23-2001 09:00 PM
