SailNet Community (https://www.sailnet.com/forums/)
-   General Discussion (sailing related) (https://www.sailnet.com/forums/general-discussion-sailing-related/)
-   -   Transporting a Snark on a Chevy Sonic hatch (https://www.sailnet.com/forums/general-discussion-sailing-related/249121-transporting-snark-chevy-sonic-hatch.html)
Billiam197r 04-16-2016 08:52 PM
Not far from where I live, someone is selling an older Snark that seems to be in good condition and a good first boat. The lightweight means I could easily handle it by myself.
The problem is transporting it. My car is a 2015 Chevrolet Sonic hatchback. At present, I don't have a roof rack or anything like that. The hull is highly likely to be too long to fit in the car even with the seats folded down.
Anyone out there have a set up that would work with a car like mine? One concern is avoiding scratches on the car's paint and making sure the hull is securely fastened.
Any advice would be appreciated.
Thank you,
-William
Sent from my A0001 using Tapatalk
CharlzO 04-16-2016 09:03 PM
Re: Transporting a Snark on a Chevy Sonic hatch
Flip it upside down on the roof, using foam tubes along the hull on each side to protect your paint on the roof (they do that with canoes), and then strap the mast to the top of the hull (which will now be the bottom as it's upside down), using your straps through the doors with windows open or closed as needed. That's how I'd do it in a pinch, at least without a trailer of any sort and a hitch.
titustiger27 04-16-2016 10:00 PM
These questions always make me wonder about the bigger question...
Is this a one time move or do you plan to need moving this two times a week?
I would add to CharlzO put a blanket on your roof
Billiam197r 04-17-2016 08:48 PM
The goal would be for this to be a one-time thing in order to get the boat home. Once home, work on something more permanent.
titustiger27 04-17-2016 09:15 PM
In that case
1) friend with truck
2) rental truck
3) previous suggestion
I know spending money is kind of hard to do.. or it is for me.
I think of it like this.. you don't have a moving van in the back yard for when you next move (which could be 10 years), much the same I don't have plumbing equipment, I just take my neighbor out to eat when he solders a couple pipes together for me.
on the other hand:
how about the more permanent situation, could you get a roof rack (craigslist)....?
If this is a new endeavor, though about the fact you might never really use the boat.. so do what is the easiest.. and if you love the Snark, you will then want a way to take care of it.
jwing 04-18-2016 03:50 PM
This method has high disaster potential, be careful! At the very least, add tie-offs to the back and front of your car to keep the boat from launching forward when you brake or jettisoning backward while you are driving. The mast and boom will be challenging!
You can rent a truck from Home Depot or Lowe's for $19.
Ultimately, a roof rack and straps are the way to go. Look for the kayak transporting accessories.
bones92 04-18-2016 04:07 PM
FWIW, we have an older but decent condition Snark Sunflower, and though I've only had it out a couple times, it's a lot of fun.
I agree... a roof rack for kayaks is probably advisable. They are much more stable when attached.
Bear in mind, a 2015 Sonic hatchback is just over 13 feet long. The Snark is probably 10 or 11 feet long, so regardless of what roof arrangement, you're likely to have a good bit of hull sticking out forward of the roof rack. Upside down, stern forward is probably your best bet, and probably err on the side of having more stick out the back in order to shorten how much sticks out in front. Go slow.
CharlzO 04-18-2016 04:38 PM
Apologies, I certainly wouldn't use just the straps on the side, but I forgot to mention the front and rear tie-downs also. In my head I was envisioning it like a flipped canoe, but didn't explain it fully.
The U-Haul idea is a good one though, just load it in the back, and even if the mast sticks out the door, you'll have the hull strapped inside to keep it from sliding, and tie the door down with just the bit of the mast sticking out the back if needed.
Billiam197r 04-18-2016 05:01 PM
How about the carrier bars on sailboatstogo.com? No attempts to set land speed records will be made.
The Home Depot idea is good except that this boat is far enough away that the extra time charges would start mounting before I could get it home, and the U-Haul would end up with extra mileage charges. Don't think I know anyone who would loan me a truck even with the assurance that I'd buy the brewskis and return with a full tank. Not because I've been a bad driver but because I don't know anyone who has a truck right now.
Why can't I find one of these in my own backyard??
SailingUphill 04-18-2016 05:09 PM
William, it's a snark, do as was suggested with the noodles... works great... to get it home... if it flops off the roof, slam the accelerator, and run like heck, the ensuing explosion of foam on the highway will be a mess to clean up!
Just only slightly kidding. The rental of a truck will cost more than the price of the used Snark (or it should).
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
