Would this make you run away? - SailNet Community
 2Likes
  • 2 Post By overbored
post #1 of 6 Old 05-31-2016 Thread Starter
Hi-Tech Redneck
Went to view a boat we're considering purchasing this past weekend.
Boat looks good, we like it a lot, and will get ALL the surveys done if we make an offer and it's accepted.
Question: Would this make you run away? It's the point where the mast transits through the deck. What you're seeing is black plastic shims, spray foam (expanding) and a big hose clamp holding the shims.
It looks like a fix to align the mast.
(Data point, this is a 1997 C400 with in-boom furling, maybe this is not the OEM mast?)
This was not noted in a 2014 survey, so it was either done after 2014 or it is not unusual.
Let me know if this would prevent you from making an offer.
Thanks for your help!
SVSoundWave is offline
post #2 of 6 Old 05-31-2016
overbored's Avatar
Re: Would this make you run away?
Mast wedges are common. most are installed from the top so the will not fall out,used buy riggers but not the spray foam, there are better ways to seal the mast to the cabin top. Google mast wedge, spartite
Faster and seabeau like this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 6 Old 05-31-2016
One of None
deniseO30's Avatar
I had a keel stepped mast.. they all leak is the word on them. The wedges should be in the top. there is also a pin that you can't see from the bottom. foam. it may be the feeble attempt to stop the water that ALWAYS seems to come in on a keel stepped mast.
but no IMO. that is a not a reason to run. In boom furling may be why the mast has been in and out how many times? .
My last project!
deniseO30 is offline
post #4 of 6 Old 05-31-2016 Thread Starter
Hi-Tech Redneck
Sorry I didn't know this, our S2 is a deck stepped design.
Thanks, folks, for the reassurance and for sharing your knowledge!
post #5 of 6 Old 05-31-2016
Not the prettiest job, good thing you've got the mast wrap.
Not a big deal, and you can always 'fix' it.
Faster is offline
post #6 of 6 Old 05-31-2016
Wedges go way back into the square-rigger days. However, as others have said, they should be installed from above. A proper job on a square-rigger, the wedges would completely ring the mast, be gently rounded, and have a lip that keeps them from slipping through. The whole affair would be covered in heavy canvas and tarred to keep the water out.
Having said that, such an inappropriate, poorly executed job would give me some concern about other repairs that I couldn't see. I think I would have one more, very detailed look, stem to stern before spending money on a survey.
elliowb is online now
how can i make the line run starboard. smallboatlover General Discussion (sailing related) 18 08-16-2011 09:41 PM
Make offer or run away? eherlihy Boat Review and Purchase Forum 56 10-03-2007 02:36 PM
China Aims to Make Run for America's Cup sneuman Racing 6 12-20-2006 01:21 PM
P.A. Denny back to make learning run (The Charleston Gazette) NewsReader News Feeds 0 05-23-2006 01:15 AM
