Water leak wifi detector - SailNet Community
post #1 of 3 Old 06-12-2016 Thread Starter
So I work for Honeywell and we just came out with a wifi leak detector where one can place the sensor anywhere. A water leak will trigger an alert to your smartphone. I decided to by 2 of these and plan on placing one in my O'Day on the floor while I am gone (the other one will go next to my sump pump at home). The marina I purchased a slip in has wifi so this should work. I plan on leaving a key for my hatch lock to the marina president who lives close by to possible go to the boat on a leak detection and see what he can do. This might just stop me from showing up and finding my boat totally submersed some day.
Just curious if anybody else uses any type of water leak detector while their boat sits in their slip?
1985 O'Day 26'
I spent all my money on booze, boats and broads. And the rest of it, I wasted. - Elmore Leonard
Bruce3966 is offline
post #2 of 3 Old 06-12-2016
travlin-easy's Avatar
Re: Water leak wifi detector
I have a leak detector on the boat, an extremely loud beeper that would be heard by the adjacent condo owners and having them call the marina office to have someone investigate it. I purchased it on Amazon for $10 and it is very sensitive. It operates on a 9-volt battery.
Gary
travlin-easy is offline
post #3 of 3 Old 06-12-2016
Cruiser
wrwakefield's Avatar
Hi Bruce,
Your detectors sound intriguing. Are they on the market yet?
Because we sometimes spend time away from the boat [and are often a day's commute away...] I ended up installing a cell based monitoring system which alerts by sending SMS messages to cell phones we select. [We also have a caretaker we can call...]
It monitors water leaks by alerting about bilge pump cycles and duration, high water alerts based upon sensor location, much more including: battery voltage, shore power, intrusion detection, geo-fence alerts, etc.
Here is my blog post about the system if you are interested in more information.
Best wishes with your new set-up.
Cheers!
Bill
PS: For local alarms in other locations of the boat [e.g., under sinks, on hull next to fresh water tanks, remote bilge locations, etc.] we use these floating [important to keep signaling...], loud, portable units from Zircon.
wrwakefield is offline
Fresh Water leak albrazzi General Discussion (sailing related) 2 01-20-2015 07:21 AM
Water leak- plumbing hasuehounds Caliber 3 06-28-2013 07:15 AM
ps 31 water tank leak Summit_Elan Pacific Seacraft 13 08-03-2012 12:57 PM
water tank leak grinfax Gear & Maintenance 2 10-15-2008 06:33 AM
'31 Citation Water Leak bruce804 Irwin 5 03-07-2008 03:36 PM
