Need help diagnosing Raymarine ST4000+ Autopilot - SailNet Community
 2Likes
post #1 of 25 Old 06-18-2016 Thread Starter
TakeFive's Avatar
My autopilot just went out - Raymarine ST4000+ wheel pilot with black wheel ring. Setting the clutch engages the wheel (can't turn manually with it engaged), like it should. And when I hit "auto" and +10 I can hear the motor whirring to turn right, but the wheel does not move. It keeps whirring every few seconds because the boat's not turning, as you would expect it to.
AP worked perfectly for survey this week, and worked for a couple hours this morning. Then it lost ability to turn left, but would turn right. A minute or so later it lost ability to turn either way. Obviously we're hand steering until we finish delivery to our new home port.
I suspect that there's a wheel, gear, or belt loose inside the wheel ring, and just needs tightening up. But it's puzzling that the clutch still grabs the wheel so well.
I'm just looking for some advice how to take it apart, and what to look for once inside.
I have the same autopilot on my other boat, but a lighter duty (gray) wheel ring mechanism for a smaller boat. But I've never had to open it up and look inside, so this is new territory for me.
Thanks for any suggestions!
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #2 of 25 Old 06-18-2016
One of None
deniseO30's Avatar
Re: Need help diagnosing Raymarine ST4000+ Autopilot
silly question... is the wheel locked? so many times we forget it
My last project!
deniseO30 is offline
post #3 of 25 Old 06-18-2016
Both versions come apart by separating the two halves by hand at the groove between them, half stays with the wheel which you removed prior to splitting the drive. There is a cogged poly belt that sometimes shreds or strips teeth, btw the gray drive units are actually the newer MarkII version, you might consider switching them before selling the other boat. There is a one inch difference in the circumference of the units which may require some changes to the mounting position.
capttb is offline
post #4 of 25 Old 06-18-2016 Thread Starter
TakeFive's Avatar
Not locked. I had checked that.
TakeFive is offline
post #5 of 25 Old 06-18-2016
CF Escapee
As described above, yank it apart.
The problem will probably be obvious.
senormechanico is offline
post #6 of 25 Old 06-19-2016 Thread Starter
TakeFive's Avatar
Will do later today.
What are the advantages of the gray Mark two version versus the black original version? And how much do I need to replace if I swap out?
TakeFive is offline
post #7 of 25 Old 06-19-2016
HANUMAN
RobGallagher's Avatar
The grey unit should be plug and play (unless something has changed). It's not that much of an upgrade, same basic principal, same cheap plastic construction. However, new cheap construction is probably better than trying to find used online or dumping $$ repairing cheap construction that is 20 years old.
The motor has a small gear on the shaft. I would start by unscrewing the motor from the drive ring. If the drive belt is engaging and you can't move the wheel then the belt is probably good. There is a small 'gear box' located were the motor is inserted, that is the second place I would look.
WINDHOVER
1999 CATALINA 36 MKII
NOANK, CT
RobGallagher is offline
post #8 of 25 Old 06-19-2016
The pin or post that mounts to the pedestal and locks the motor half from turning must be moved up less than an inch, sometimes just flipping it over and reusing same screw holes works because it's offset slightly.
On Catalinas with an engine panel in a pod on the pedestal sometimes the motor on the gray unit will hit/interfere with stop handle, key or pod when mounted in the "preferred" position with the motor located in the lower starboard quadrant of the wheel. It is sometimes required to use the "alternate" mounting postion provided for by RM by rotating the drive 180 degrees so the motor is in the upper port quadrant of the wheel, which feels a little backward when you operate the clutch until you get used to it.
Sometimes neither position clears and you create a new mounting location by drilling a new hole in the motor plate of the drive to locate that post.
FWIW at it's introduction the gray unit was supposed to have a little more torque, beats me, my primary drive is a black one labeled Autohelm from '95 with a new belt, back-up is also black one labeled Raymarine from '02. I sold my old boat with a new gray unit and bought a boat with an older one. Can't justify a new one until I break a couple old ones.
Also are you aware of the "Catalina Cocktail" ? That's a recommended list of settings for a RM wheel pilot to compensate for the limited number of turns lock-to-lock on Catalinas.
"Just call me TB"
capttb is offline
post #9 of 25 Old 06-19-2016 Thread Starter
TakeFive's Avatar
I took the motor off - gear looks fine. I did not separate the rings - I'm taking it home to disassemble.
When I re-tested it, it looks like there's a very thin metal cable (1/16") that has a little slack, and is trying to slip through the slit between the two rings when the motor actuates. Does that give any clues to the problem?
I'll provide more info when I get home. Right now I'm just too hot.
TakeFive is offline
post #10 of 25 Old 06-21-2016
TomMaine's Avatar
Carefully check the belt. There could be a worn spot that is hard to see. I have 15 seasons on an ST4000 and am on the 4th belt. I'm amazed how long it's lasted.
It's just about perfect for our coastal sailing.
Tom Young sailing a 1961 38' Alden Challenger, CHRISTMAS out of
Rockport, Maine.
'I'd have written a shorter post, but I didn't have the time', Mark Twain.
TomMaine is online now
Raymarine ST4000 MK2 Autopilot Gearbox info? Allatsea Electronics 1 06-05-2014 09:58 PM
Autopilot ST4000 hangupndrive Gear & Maintenance 19 04-25-2010 08:51 PM
Another St4000 Autopilot Question tomandchris Electronics 0 04-21-2010 10:30 AM
Diagnosing a problem with factory installed Raymarine navtronics vwbrady C310 0 08-05-2008 04:55 PM
Raymarine ST4000 Autopilot.... clayjay Gear & Maintenance 4 03-26-2008 02:58 AM
