Baby step in the ocean - Page 2 - SailNet Community
 4Likes
post #11 of 16 Old 06-24-2016
Old as Dirt!
svHyLyte's Avatar
Re: Baby step in the ocean
Originally Posted by SVSoundWave View Post
Intermediate experience/skill. Sailed about 1500 nm total, owned 3 sailboats in 26-38' range. Worst we've endured is only 30kt winds, 6' seas
Sailed Chesapeake, Albemarle, Pamlico and Charleston no offshore.
SoundWave--
That is certainly enough background for this little traverse. You should do fine. A couple of added thoughts:
Ensure your reefing gear is in order and (given a new to you boat) that you know how it works, especially so if you elect to travel at night, which I would on a similar passage on the east coast of Florida. In some respects, travel at night is easier than during daylight hours. There are far fewer "day trippers"/recreational fishing boats to contend with. Ships traveling at night along the coast are generally well lighted--cruise ships like floating billboards--and can be seen far further off than the same ships during the day when they may fade into the background haze. Ships also normally maintain steady courses and speeds so watching their lights one can pretty easily tell whether they are crossing your course and whether a minor course adjustment to (further) avoid them is advisable. Hopefully you have radar with which one can track weather/squalls pretty easily. If not, however, you can still usually see/detect squalls before they get to you, particularly so if you have moonlight. On clear moonless nights a squall will create a big empty black spot in the sky where one would otherwise see stars. Squalls are usually also preceded by cool winds that differ from the ambient wind conditions. The first time you suddenly feel them is when its time to reef. Keep your hatches closed and drop-boards in place lest a "sneaker" wave give your boat, and your accommodation without doing so, a good soaking. Lastly, of course, ensure everyone on deck is tethered to the boat and, preferably, wearing inflatable life vests (our "First Rule" aboard is "Safety First").
Ensure your fuel filter(s) is/(are) clean and that your tank is filled with fresh fuel to the extent possible. Having to change a clogged filter and bleed an engine's fuel system while underway can be a serious pain in the neck (literally and figuratively).
If you don't have a EPIRB aboard, pick one up before your trip at least an ACR PLB which costs less than $250.00 with free overnight delivery from several vendors.
Finally, in re: Radio Check complaints, one can make automated radio checks on Channel 27 that has a transponder that records transmissions received and then re-broadcasts them. With that you can hear your own transmission (or not!) and know whether your signals are getting out.
Hopefully the foregoing does not sound too pedantic. If so, forgive me, eh?
FWIW...
RichH and SVSoundWave like this.
svHyLyte is offline
post #12 of 16 Old 06-24-2016
RichH's Avatar
Traveling 'outside' along the east coast involves 'inlets', many (less than Class A inlets - used by 'ships') with sandbars at where the inlet's current meets the ocean.
Traversing inlets with the 'wrong' wind and current, these inlets can sometimes be 'very difficult'. These minor and 'less than Class A' inlets are also 'shifty', the USCG constantly changing the channel markers as the bottom contours of the 'channel' shifts about and changes - the reason that most charts and chart plotters will have the markers 'absent'. It takes quite a bit of practice and expertise to 'shoot' an inlet during 'the wrong' times .... you'll get better at it, the more inlets you use.
So, unless you have 'local knowledge', many times you'll have to WAIT outside or reduce/increase your boat speed to these smaller inlets so that your 'timing' is correct to safely enter, ....... or simply travel on to the next (or turn back to 'the last') inlet so the 'timing' is more correct. Many of these minor inlets will NOT be suitable for 'sailboats' in any conditions --- without specific 'local knowledge'. When in doubt, contact the local USCG on VHF channel 22a for specific inlet info.
You usually don't use such inlets when there is a large/high easterly (NE/E/SE) swell and an outflowing/ebbing current. When 'shooting' such inlets, you want to preferentially do so on 'slack' current or a flooding ('in') current - for less 'standing waves' height. What you don't want to do is to blindly enter (or cross the 'outer bar') and find the standing waves are much larger than what your boat can safely handle and then find you CANNOT do a 180 without broaching, etc. - trapped!!! Correct 'timing' will help you avoid this.
If in doubt and you do decide to enter in 'boisterous' inlet conditions, consider to have the boat totally closed up, including the companionway, and with PFDs, etc. 'on'. Some of the east coast inlets are notoriously bad during the wrong conditions; and the prudent sailor will usually 'stay out' and not enter during the 'wrong' inlet conditions (and especially with a dirty, crudded-up fuel tank !!!!).
For the Southeast, mid-Atlantic and New England coasts, the best reference is "Eldridge" Tide and Current tables ..... Eldridge Tide and Pilot Book 2016 "Eldridge" is based on 'historical' data, not 'just' computer generated data.
Do consider to have an accurate *tide and current* program as a backup for your tablet, smartphone, etc.
RichH is offline
post #13 of 16 Old 06-24-2016
okawbow's Avatar
A few years ago my Wife and I sailed our Cheoylee 31 ketch from Big Key to Savanah, Georgia on the "outside" as one of our jumps from Kentucky Lake to northern Maine. We made 2 more offshore "jumps" before going in to see the Dismal Swamp, and go into the Chesapeake.
We passed Miami in the late evening. We stayed offshore just far enough to get a little favorable current, but it seemed the ships stayed out farther except at inlets. There were lots of small fishing boats to avoid, and some were unlit, so a watch is necessary at all times. I felt that sailing at night was easier than sailing during the daytime when staying within 10 miles of shore. Fewer boats to avoid, and the weather was generally calmer.
You could accomplish 2 firsts at the same time by doing your first offshore and first night sail.
Good luck and enjoy your sail!
Chuck
Privateer 26 Schooner
okawbow is offline
The Following User Says Thank You to okawbow For This Useful Post:
SVSoundWave (06-24-2016)
post #14 of 16 Old 06-25-2016
FSMike's Avatar
Originally Posted by eko_eko View Post
-----If you don't want to try Lake Worth, Port Everglades is a pretty easy inlet and there's a good anchorage near by (Lake Sylvia).
Port Everglades makes for a lot shorter day, although you do have a lot of bridges to deal with between there and Lake Worth.
Better check on the latest status of anchoring in Lake Sylvia, I think there is some difficulty doing that now, maybe check ActiveCaptain or some other current source.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #15 of 16 Old 06-25-2016
Eldridge is great in New England, and nearly useless in Ft. Lauderdale. There's no detailed current mapping, just tables which you can get free from NOAA. The Eldridge tables require you to do math based on the predicted time and the reference inlet. It's a pain and based on old models.
Here's the guide for Port Everglades:
tidesandcurrents.noaa.gov/noaacurrents/Stations?g=451
It will be more up-to-date than anything published on paper the previous year, simply because they are actively working on improving the models and there are several depth and speed sensors in the inlet.
Here's the list of all the Florida stations for which you can get good data from NOAA: tidesandcurrents.noaa.gov/noaacurrents/Stations?g=451
Eldridge was indispensable in Boston and around Cape Cod. In S. Florida, use NOAA.
1975 Tartan 30 Competition Rig
eko_eko is offline
post #16 of 16 Old 06-27-2016
RTB
TROUBLE
RTB's Avatar
The last comment on AC was yesterday. No problem.....but July 1 is the date the new restrictions go into effect. I don't think Lake Sylvia was included anyway.
Ralph
S/V FUGUE
HUNTER 36
KEMAH, TX
RTB is offline
Tags
miami
Ocean baby rescue underway off Mexico flyingwelshman Vessels Lost, Missing, or in Danger 619 07-26-2015 08:11 PM
'Seriously ill' baby girl rescued from stalled sailboat in Pacific Ocean - New York D NewsReader News Feeds 0 04-07-2014 03:10 AM
UPDATE 1-Frigate nearing sailboat with sick baby in Pacific Ocean - Reuters NewsReader News Feeds 0 04-06-2014 03:00 AM
Is there a step by step for a stepping of the mast? Skipper Joe Gear & Maintenance 5 07-15-2009 08:45 PM
Winterization List: How to Winterize? Step-by-Step Photos? captxtina Gear & Maintenance 8 10-25-2008 11:12 AM
