Stanchion Height - SailNet Community
post #1 of 3 Old 06-24-2016 Thread Starter
Stanchion Height
I'm in the position of having to replace the stanchions on my boat (an S&S 34). The existing setup uses 24 inch high stanchions, which I believe is pretty standard. I'm considering going to 30 inch stanchions. Curious if anyone has a view as to the utility (or non-utility) of taller stanchions.
Thanks in advance.
Plumbean is offline
post #2 of 3 Old 06-24-2016
Stu Jackson's Avatar
Re: Stanchion Height
The general view is always higher is better. However, if you change the height of the top lifelines, whatcha gonna do with the bow & stern pulpits? It won't look too silly at the bow, but the stern sure will.
OTOH, the very best advice I've ever read (on CF) was: "Treat the edge of your boat as a 500 foot clif."
"Depending on "life"lines to "save" you is a fool's errand.
Good luck.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #3 of 3 Old 06-24-2016
Old enough to know better
If you go from 24 to 30 inch stanchions, don't just replace the stanchions, make sure you replace the bases and beef up the backing plates (if there are any) because the longer the lever, the higher the loads. Most bases are kind of stressed at stock heights. I guess another disadvantage is the higher the life line is the more room you will have to side under it, as the lower line is likely to be set higher as well.
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
Stanchion base jharvey1215 C & C 1 07-07-2013 03:39 PM
rebedding stanchion Julie303 Gear & Maintenance 5 08-21-2010 05:24 AM
Spinnaker pole height: no downhaul, no adjustable height aarhus Learning to Sail 5 08-16-2010 05:37 AM
Filling a Stanchion? Mandofish Gear & Maintenance 12 08-27-2009 11:56 PM
stanchion and rudder for S2 9.2 DixieChick Gear & Maintenance 1 02-01-2006 05:19 PM
