Converting Starboard Settee to Double Bed - Page 2 - SailNet Community
 4Likes
post #11 of 22 Old 07-06-2016
Omatako's Avatar
Re: Converting Starboard Settee to Double Bed
Originally Posted by clifgray View Post
But my main holdup now is where to put the mattress pad for the extended part of the bed... .
So you don't have a backrest cushion on the bunk? Using one as part of the mattress makes for more width as well.
Barquito and seabeau like this.
Arthur C. Clarke
Omatako is offline
post #12 of 22 Old 07-07-2016 Thread Starter
OBX Sailor
I tried to pull the backrest cushion off last week and it seemed pretty well fastened but I'm sure it will come off now that I actually think about it. I'll try that tomorrow and see how it works! I may also see if I can get a nice little mattress topper that will fold up into a box to stow away when needed.
Need to do some measuring...
clifgray is offline
post #13 of 22 Old 07-14-2016 Thread Starter
OBX Sailor
Finally got the outboard fixed so on to new projects!
@Omatako so as it turns out the backrest cushion pulls right off without any issue. So I'll plan to use that as the second half of the bed and that makes storage easy!
clifgray is offline
post #14 of 22 Old 07-14-2016 Thread Starter
OBX Sailor
Originally Posted by pdqaltair View Post
Different boat. But like this:
Because there is a table there I do not need a fiddle. Why not just use the convertible table? Because this is MUCH easier to rig at night (the table is heavy and has stuff on it).
Instead of legs I have a wooden box/step that is shoved under it. Stronger, and it is only used on the cockpit during the day. I add a mattress topper for comfort and to cover the joint in the cushions, and a twin fitted sheet.
That looks and sounds great! What do you mean you don't need a fiddle? I'm not sure what that is. The only other thing I'm not clear about is what is actually support the additional bit of bed. Does that wood panel have a hinge on it and swing up to support the additional bed? And if so did you just drill through the fiberglass to put the hinge in? I like the idea of a box under there instead of some legs.
clifgray is offline
post #15 of 22 Old 07-14-2016
travlin-easy's Avatar
My backrest cushion was held in place with snaps and it was very difficult to remove from the bulkhead. I lubed the snaps with WD 40 and it made the job much easier.
Gary
travlin-easy is offline
post #16 of 22 Old 07-29-2016 Thread Starter
OBX Sailor
@pdqaltair wanted to ping you again in hopes you can answer the above questions!
clifgray is offline
post #17 of 22 Old 07-29-2016
Guyfromthenorth's Avatar
I didn't read the whole thread (hitting the road shortly!) but my 25' has a pull out bed fashioned in the port side settee. What they did was cut a piece of plywood (5\8 or thicker) in the shape of the underside of the cushion, removed that front wood kickplate (as seen in your pictures) that holds the seat cushion from slipping forward and screwed it into the edge of the plywood. Slots were the cut near the end of the plywood where the plate is attached to fit legs.
When we need the bed extended the plywood sheet pulls out like a drawer (by pulling on the wood faceplate\kickplate), the seat cushion comes with it, the "back" cushion slides down and lays perfectly in the spot the seat cushion was in and then you slip the legs from underneath into the holes cut into the plywood and voila you have a larger bed. Make sure to leave the plywood long enough so 6in or more remains under the cushion to support that end and at the bottom of the feet I used hardwood trim squares. They can be found at hardware stores and usually go in the corner of door trim so you don't need to match 45deg cuts, they are hardwood and usually 3in by 3in.
I can try and find pics if it helps, I'm 3hrs from the boat currently and won't be there till maybe Sunday night or Monday afternoon.
Edit: yeah I'm no artist
https://s31.postimg.org/4yi3ltz97/20160729_165831.jpg
Some youtube videos, nothing fancy
Guyfromthenorth is offline
post #18 of 22 Old 07-29-2016 Thread Starter
OBX Sailor
This sounds like more or less exactly what I'm shooting for at this point. A couple pictures would be awesome!
Where do you store the legs when not in use?
clifgray is offline
post #19 of 22 Old 07-29-2016
I have a small drawer right beside the settee that they fit in nicely. The legs were made from maple boards, I believe they measure 3in wide by 3/4in thick. They were cut to shape with a bandsaw and have the shoulder design up top as somewhat depicted in my laughable diagram lol. I can certainly snap a pic and upload it when I'm at the boat after the weekend, it's a pretty simple mod that works awesome.
The only caveat I found with it is because there is a sheet of plywood under the cushion it's somewhat harder to access the storage underneath compared to the starboard side where it's just a cushion I can fold up out of the way. But the small issue is far outweighed by the larger bed access. Also under the plywood is a small strip of thin carpet (think thinner than astroturf) so it slides smoothly in and out.
post #20 of 22 Old 08-01-2016
Bear with me as I'm doing this from my phone.
Here's some pics:
Pic 1 settee as is (only a 25 ft boat so it's tight snapping pics!)
https://s32.postimg.org/we3g4pq05/20160801_200556.jpg
Pic 2 cushion removed to show the plywood base
https://s32.postimg.org/m5uv2zwh1/20160801_200657.jpg
Pic 3 better shot showing the holes for the legs and how the faceplate is attached
https://s32.postimg.org/6x59a22ud/20160801_200707.jpg
Pic 4 pulled out to double mode
https://s31.postimg.org/6gfmw3o9n/20160801_200829.jpg
Pic 5 shot of the legs installed
https://s32.postimg.org/7rjzqld9x/20160801_200848.jpg
Pic 6 legs on their own
https://s32.postimg.org/4z4xjybk5/20160801_200538.jpg
Pic 7 and 8 pulled out legs in but no cushion
https://s31.postimg.org/l07woj9nf/20160801_200919.jpg
https://s31.postimg.org/yftynu58r/20160801_200909.jpg
Hope that helps!
Converting to double-line reefing MarkSF Gear & Maintenance 21 07-09-2012 10:45 PM
Converting a settee/pilot berth to a dinette. SVDistantStar Gear & Maintenance 2 10-13-2008 09:54 PM
