Spinnaker without a pole - Page 3 - SailNet Community
 27Likes
post #21 of 34 Old 08-24-2016
Freedom isn't free
Dock
Re: Spinnaker without a pole
Love the comments about how it won't work, and how to do it after I showed pictures of it done. This is why I love the internet.
Answer is you can fly between about 130 and 120 degrees AWA in light air (under 10 knots true) with it being only slightly better than a 155% genoa. Does that help?
Oh and others suggest a moveable tackline.. YEP... and if you can get the clew to ride up the forestay (as was suggested with the ATN tacker or beads) then by all means do so... the prior owner to my boat fixed that problem too by putting a hank on it near the clew (you can also see in this picture).. He must have really hated spin poles...
Minnesail likes this.
Freedom, a 1983 C&C 32 sailing Smith Mountain Lake, VA
SHNOOL is online now
post #22 of 34 Old 08-24-2016
Chastened
Ajax_MD's Avatar
LOL...ok, sure you can do it. I can bang nails in with the handle of a screwdriver but it's slow and painful and damages the screwdriver. You just said yourself that it's only marginally better than using a plain ol' genoa.
The OP said that he just wants to see the big sail fly and say "Whee!" Ok cool, I get that so have at it. However, if he decides to get more serious about it, I suggest that he either buy an asymm or buy the missing bits and bobs to fly a symm the way it was meant to be used.
sailingfool likes this.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #23 of 34 Old 08-24-2016
Pretty silly this. Deep on the wind a symmetrical tacked to the stem is far more powerful than a genoa shadowed by the main.
Only cruisers tack spinnakers to the headstay. That seems pointless to me. Tacked to the stem the spinnaker can fly far to windward: powerful. The lee shoulder of the spinnaker will be flying beyond the main shadow as well. But it does look a little goofy. I would definitely do it if my predicament made it my best option...broken pole or torn asymmetric.
Works fine. And we saw pics above too!
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
post #24 of 34 Old 08-24-2016 Thread Starter
Minnesail's Avatar
I have a 170 nylon genoa / drifter that I can use from close-hauled to a broad reach, so it sounds like mis-using my symmetric spinnaker won't get me anything I can't already do. Maybe this is what people mean when they say it won't work.
Nonetheless, this is my third year with the boat and I've never used the spinnaker. Even if it's less effective than my drifter I want to get it flying just for kicks.
Wow, that hank looks like it could be a hazard if you ever used that spinnaker in the regular way. Also it seems overly complicated. Wouldn't a shackle or carabiner through the tack and around the forestay accomplish the same thing, without permanently modifying the spinnaker?
So it sounds like my setup should be a small block set in front of my forestay, a line run from the cockpit through the block to the tack, a shackle or carabiner to slide the tack up and down the forestay, and long spinnaker sheets run outside the forestay.
Catalina 22
on a starboard tack
Minnesail is offline
post #25 of 34 Old 08-24-2016
Freedom isn't free
Dock
Displacement boats don't generally benefit much from an asym... at least not without a sprit... its strictly a downwind sail, and yep your 170 light air killer will likely be better. This might sail you just a bit deeper but not enough to matter. Someone considering this would likely not even have a 155.
Yep the prior owner of that boat I had lost the spin pole... so it was never used the "right" way, so the hank wasn't a concern... Also the boat came with a furler and a 110 on that furler, so he was looking for something for light air and downwind.
I later added a pole to the boat, a better spin, and a decent laminated 155. Then I sold the boat, and bought something faster, that was already rigged for a symmetrical spin.
RichH and Minnesail like this.
post #26 of 34 Old 08-24-2016
Moderator
MarkofSeaLife's Avatar
Dock
Originally Posted by Minnesail View Post
this is my third year with the boat and I've never used the spinnaker..
Unless I am racing I could never be assed. Run all those lines just so the wind can change? That's crew work!
SHNOOL and Minnesail like this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #27 of 34 Old 08-25-2016
ASA and PSIA Instructor
Do yourself a favor and buy a spinnaker pole so you can use your spinnaker. A spinnaker allows you to keep sailing in the common circumstances of low wind pressure after the beam. I use mine regularly. You can leave you spin sheets run, ready to use, just hang off the stern rail.
sailingfool is online now
post #28 of 34 Old 08-25-2016
RichH's Avatar
The Catalina-22 has a J dimension of only 8 ft. Spinnaker poles are typically a 'scoch' larger than the J dimension. For a Cat-22 a ~9ft. aluminum spinn. pole of 1-1/2" dia. would be relatively insignificant in cost; most of the end connections/fittings are easily obtainable on the internet: mast ring connector (you really don't need a mast track for the spinn pole @ 8-9 ft. long, end fitting spring jaws, spinnaker sock, etc. etc. Hell, Sailrite.com has a kit for your your boats spinnaker for moderate $$ and you can reef the spinnaker with the 'sock' if needed.
For sail control, I recommend (all from the cockpit), a pole topping lift / downhaul, ... 'twing' lines that are terminated to plastic rings (the spinn sheets pass through the plastic rings) ... when the twings are pulled 'down' they act as a substitute for foreguys. Plus, I'd add deep grooved sheaves to the outboard side of base of the cap shrouds .... so sometimes instead of using the 'twings', simply place the windward spinn sheet under the windward roller mounted to the cap shroud, etc. etc.
All this is to keep the spinnaker STABLE under varying wind strengths and course angle .... the lower the wind speed, the lower the pole; and vice versa etc. If the symmetric is pinned to the stem or the forestay of the boat you're simply not going to have a STABLE spinnaker at other than very light wind speeds.
Consider to set up the boat properly to fly a symmetric spinnaker ... its not going to cost an arm and a leg for a boat with an 8 ft. "J" dimension; plus, you will have a STABLE spinnaker (not oscilating back and forth .... and driving you 'nuts'). Id suggest TWO LINE (spinn sheets) control with adjustable 'twings' to substitute for foreguys (used for 4 line control)..... and you'll find very quickly that you'll REALLY NEED to raise/lower that spinn pole to keep that spinnaker STABLE.
hope this helps.
RichH is offline
post #29 of 34 Old 08-26-2016
Minnesail - I have spinnaker pole from a Chrysler 22 that you can have. I don't know anything about it because I never used it and no longer have the Chrysler. The pole has a curve to it that I'm not sure if it's suppose to have or not and it has a bunch of rigging attached. I'm in Coon Rapids if you're interested.
Catalina 25
threeagon is offline
post #30 of 34 Old 08-26-2016 Thread Starter
Minnesail's Avatar
Really?! That'd be awesome! Are you around this weekend?
Catalina 22
on a starboard tack
T30 ...spinnaker pole... And short pole next to it... CleveRland Sailor Tartan 14 05-20-2015 10:54 AM
whisker pole or spinnaker pole ltgoshen General Discussion (sailing related) 11 06-20-2012 02:38 PM
Using spinnaker pole to pole out jib when sailing downwind... sweetdreamyamaha Seamanship & Navigation 5 09-08-2010 11:39 AM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 03:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 03:10 PM
