Catalina 27 questions - Page 3 - SailNet Community
 7Likes
post #21 of 33 Old 09-13-2016
The most female moderator
Donna_F's Avatar
Dock
Re: Catalina 27 questions
Originally Posted by archimedes View Post
Also, knowing nothing about diesel inboards, I'm a bit intimidated about that.
If I can grasp the concept of a diesel, almost anyone can.
It makes me lean more toward an outboard. The outboard setup on the Pearson 26 was really simple and worked well enough. At this point all of the C27 inboards are ~30 years old or more. Ticking time bomb? ...
We had to repower to replace a 30 YO diesel. I would guess it depends on how well the PO kept up the engine but ours was, in fact, a ticking time bomb that finally went off when we were away from our marina. We got maybe two more years out of the engine after we bought the boat.
travlin-easy likes this.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #22 of 33 Old 09-13-2016
Tiller.
tellemark32 is offline
post #23 of 33 Old 09-13-2016
roverhi's Avatar
Diesels are really easy, put in clean fuel, have a good water separating fuel filter, change the oil and adjust the valves at least annually, and turn the key. Should start in a couple of revolutions if it's not cold out and even then with Cold Start function or Glow Plugs, it should start quickly. If it doesn't start quickly get nervous because it may have low compression and need major work. Diesels are no brainer engines with only a little care in maintenance.
It's a tribute to the good old Atomic 4 that so many are still running 50 or more years down the line. Actually it's a much smoother and pleasant engine for a sailboat. Parts, freshwater cooling kits, electronic ignitions and rebuilt engines are still available. A bit more work to keep running because of the ignition system on gas engines and you have to take a little care because of the fuel. Hear of more explosive issues with propane than I do gasoline.
As I stated earlier, there is something to be said for the simplicity of an outboard but they can have issues in rough sea conditions.
If Catalina left the tiller rudder shaft in place for an emergency tiller, changing back to tiller would be a matter of getting a tiller head and tiller, removing the wheel pedestal and filling the hole in the cockpit sole. May even be able to make money if there is someone out there dumb enough to want a wheel. Catalina has a pretty good parts department, may be able to source through them is you couldn't find a used one.
Thanks for all the input folks.
I've been sailing 19-22ish foot day sailers for years, until this summer. All summer I sailed a Pearson 26 with a tiller, outboard, and the traveler aft. Real nice setup, much like sailing a big dinghy. I was really happy how quickly I picked it up. Felt a bit worried until I got out on it - but it was real simple. No standing headroom though, as I am 6ft.
The Catalina has standing headroom, barely.
I think my mind is made up on the tiller vs wheel. I've always wanted the tiller. The problem is that tiller versions are fairly rare compared to wheel steering boats - esp. in boats built in '84 or newer (which is what I want). The 84' and later boats have a more modern interior, internal halyards and other improvements.
Assuming I get a boat with a wheel and don't like it, how big of a deal is it to switch back to a tiller? I can't remember where, or whether, the C27 has the tiller attachment still in place on wheel version boats.
Also, knowing nothing about diesel inboards, I'm a bit intimidated about that. It makes me lean more toward an outboard. The outboard setup on the Pearson 26 was really simple and worked well enough. At this point all of the C27 inboards are ~30 years old or more. Ticking time bomb? You can get an outboard version easily for 5k (maybe less). But almost all of the inboard boats I've seen are 10k or more. Seems like a big premium for a boat with a 30+ year old inboard.
roverhi is offline
post #24 of 33 Old 09-13-2016
flo617's Avatar
My Yanmar 2GM20F diesel has never (truly) failed me when on the water. It always starts on the first try except when the battery is dead of course. That being said I can't say I love it. Access is usually hard on these small boats and there is maintenance to be done on it in sometimes painful to reach places. It has a tendency to stink up the cabin when I use it for a long time. It also depends on how well it was installed in the first place. Check for the engine mounts to make sure they are serviceable (no rotten wood underneath or mounts beyond recovery) and that the fuel tank is not rusting away etc... Like Roverhi mentioned, on a formed sea, a diesel with a prop deep in the water will perform much better than an outboard, always good when that cargo ship is getting a little too close for comfort and there is no wind but if it's just to get in and out of the slip it's another story.
Another advantage of an inboard is the fact that it won't be stolen. Outboard theft is rampant in my neck of the woods.
PS: tiller all the way. On a wheeled Catalina30 I checked a long time ago, the rudder stock was protruding in the back. If that's the case it should be very easy to change back to tiller.
flo617 is offline
post #25 of 33 Old 09-13-2016
There are so many C-27s out there you should be easily able to find one with the steering and traveler arrangement you want. I'd recommend tiller and outboard. Tiller because it's more fun and opens up the room in the cockpit. Outboard because the engine access is pretty tough on a C27 and outboards are cheap. OTOH, 'cause it seems folks can't even give away a gas powered boat, one with an A4 inboard will be pretty inexpensive.. (A brand new A4 is only about $6K - likely 2x what the boat is worth)
They're a great get-out-there cheap boat.
(I own a A4 powered C-30, so I'm a bit biased)
gptyk is offline
post #26 of 33 Old 09-14-2016
azguy's Avatar
I've sailed on both and would not in a million years buy one with a wheel, it made getting around the cockpit a real pain in the arse
1988 C22 Owner
azguy is offline
post #27 of 33 Old 09-15-2016 Thread Starter
Originally Posted by chip View Post
I love the tiller on my C27. The rudder is somewhat balanced, so the tiller feels light (lighter than the tiller on my C22, even though the boat is much heavier). My traveler runs along the leading edge of the lazarette, so the main sheet is within easy reach, and I have a tillerpilot to make single handing easier.
I'm sure there are advantages to a wheel too, but I wouldn't personally want one on this boat.
That's a nice setup. I wish I could find one like that. Can you have a bimini with the mainsheet where it is?
archimedes is offline
post #28 of 33 Old 09-15-2016
travlin-easy's Avatar
archimedes, That's identical to the setup I had with my 1968 C-27 - very easy to single hand that boat.
Gary
travlin-easy is online now
post #29 of 33 Old 09-15-2016
Fortuitous
chip's Avatar
It's not ideal for a bimini. It's probably possible, somehow, but it would be a serious compromise without great cockpit coverage.
It's great for sailing though.
My Boat Log, or "blog" if you will:
chip is offline
post #30 of 33 Old 09-16-2016
Chip, it was not a problem with the bimini, no more problem than the backstay. Most of the time you are sitting far enough forward that you are well shaded by most bimini setups.
Gary
Questions on the Catalina 445 SailingJackson General Discussion (sailing related) 19 01-17-2015 07:28 AM
Catalina 34 questions rmjohns Catalina 0 10-07-2014 10:26 AM
Catalina 26 questions captainfletcher Boat Review and Purchase Forum 3 04-12-2013 05:14 PM
catalina 27 questions BB61sailor Boat Review and Purchase Forum 6 10-22-2008 12:08 AM
Catalina 27 sail questions???? wildcard Gear & Maintenance 8 05-20-2007 05:40 PM
