ST60 Wind Transducer does not show correct true wind - Page 2 - SailNet Community
 2Likes
post #11 of 19 Old 09-19-2016 Thread Starter
TakeFive's Avatar
Re: ST60 Wind Transducer does not show correct true wind
Originally Posted by senormechanico View Post
Move the air conditioner??
Not a chance.
The A/C was installed less than 3 years ago by PO. Airflow is great (excellent ducting), through-hull locations are great, everything works perfectly, and I used it all summer. Why would I rip it all out and move it and all the ducting somewhere else?
Paddlewheel speed is obsolete technology, needs constant maintenance, and often gives questionable readings even when it's maintained. My only reason for wanting it is the wind transducer wants it for true wind speed and direction while underway - and those values are as unreliable as the STW readings.
If there is no way for the wind instrument to accept SOG instead of STW (and that's not proven yet, since someone said there may be a setting), then I will send apparent wind (and all other SeaTalk information) to my tablet chartplotter by WiFi and have software calculate true wind. I already have all the electronics to do this (brought them over from my prior boat), I just need time in the offseason to do it.
It would have been nice if I could figure a way to have my wind control head accept SOG instead of STW, but if I can't then I'll do it a different way.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #12 of 19 Old 09-19-2016
Mermaid Hunter
SVAuspicious's Avatar
I may have a chance to confirm using SOG v. STW on a Garmin chartplotter today.
Seeing reliable STW and SOG gives you good data on currents.
SVAuspicious is offline
post #13 of 19 Old 09-19-2016 Thread Starter
TakeFive's Avatar
Hi Dave, I do realize that comparing STW and SOG can get useful information if STW is reliable. But having moved from the 2-3 kt currents of the Delaware River to the Chesapeake, the currents are too low for me to care much at this point. (I know that will eventually change.)
As for the Garmin chartplotter, my very old 2010 model does not display wind data, so even if I could convert wind data from SeaTalk to NMEA0183 on a wire, it would not help me. However, your information could be helpful if I want to consider a future upgrade to a newer Garmin model.
For now, my Garmin chartplotter is my foul weather backup. In dry conditions, my primary chartplotter is OpenCPN on a windows tablet, nicely mounted at the top of my binnacle. And once I have my SeaTalk-Wifi converter installed, it will give a very nice comprehensive display of all my current nav data. But ultimately a purpose-built chartplotter display is the more bulletproof solution.
TakeFive is offline
post #14 of 19 Old 09-19-2016
Super Moderator
Maine Sail's Avatar
If you want more accurate true wind data for your "boat" then add an ultrasonic speed log.
Using SOG gets you ground-wind data not true wind data for your boat, which is moving through water. I don't know of any ST-60 or ST-60+ wind instruments that can read SOG sentences unless a software update happened that I missed. ST-60's use STW (speed log (if well calibrated), COG (usually the flux gate (if well calibrated) and Apparent wind to attempt to calculate true.
If you really want "true wind" on a boat.... Good luck... It's a rough guide at best...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #15 of 19 Old 09-19-2016
Ultrasonic speed log?
I'm having a similar set of issues. ST60+, ST6000+ and a 3210.
Even with a new paddlewheel I was getting poor true wind readings
xort is offline
post #16 of 19 Old 09-19-2016 Thread Starter
TakeFive's Avatar
To me, it's not worth investing any significant money. It is worth some effort to adjust my current hardware to extract the most information possible.
There are other things that are much more important right now (such as reliable shifting of my transmission), so this one's down the list for the offseason...if then.
TakeFive is offline
post #17 of 19 Old 09-19-2016
Super Moderator
Maine Sail's Avatar
Yes Airmar makes an Ultrasonic speed log called the CS4500 and it is available for all brands. This is not a new prodcut just one that you don't hear much about because they are pricey, about $700.00 - 750.00 just for a plastic transducer (P17). While not inexpensive they work really well, are more accurate & remain more accurate than a paddle wheel. They require virtually no maintenance.
They also offer a converter box to get it over to NMEA 0183 or NMEA 2K but the Raymarine ITC-5 can also convert the analog signal as well as wind, depth/temp, rudder and flux gate to NMEA 2K.
______
post #18 of 19 Old 09-19-2016
Thanks...but no thanks!
I just recently blew my wad on some electrical. ;-)
Tapped out!
xort is offline
post #19 of 19 Old 09-19-2016
overbored's Avatar
Just add this set up last month and was $635 with plastic housing about $100 more for bronze housing, it works great and I had one one my old boat and it worked for 6 years while I had it and is still working today.
"GOLD RUSH" PRINDLE 16
overbored is online now
ST60 wind display Minnewaska Gear & Maintenance 5 04-27-2014 03:47 PM
NKE wind transducer to which wind display via NMEA 0183? Rupeski Electronics 9 02-12-2014 02:29 AM
Raymarine ST60 Wind tdw Electronics 9 12-28-2011 09:44 PM
True Wind vs Crazy Speed Transducer bacampbe Electronics 16 10-15-2009 11:17 AM
ST60 wind initialize? mikehoyt Gear & Maintenance 5 10-02-2008 10:04 PM
