Hugh's Log - Page 3 - SailNet Community
 32Likes
post #21 of 75 Old 02-23-2017 Thread Starter
Dock
re: Hugh's Log
It took a couple of weeks to source the wood for my gunwales and a few trips to Home Depot to stock up on clamps and then a week or so of scratching my head before calling up one of my buddies to come help me out, but now I've got breasthook and gunwales installed. Next will be the forward bulkhead and transom and then the critical step of making sure the boat is square before I start epoxying the seams.
p.s.: Anyone know how to rename a thread? Since I plan on using this thread long term to chronicle my journey into the world of sailing I was hoping it could be renamed 'Hugh's Log' .
thanks,
Hugh
WP_20170220_14_24_36_Pro.jpg   WP_20170222_20_34_30_Pro.jpg   WP_20170222_20_35_03_Pro.jpg
ThereYouAre is online now
post #22 of 75 Old 02-23-2017
RocketScience's Avatar
re: Hugh's Log
thanks,
Hugh
PM (private message) one of our great Moderators. They can do it.
Synthetic Rigged Wauquiez Pretorien 35
RocketScience is offline
post #23 of 75 Old 03-20-2017 Thread Starter
Dock
re: Hugh's Log
I've installed the forward bulkhead and I spent a couple of days planning down the gunwales and installed the forward and nesting bulkheads as well as the transom. I checked that the boat was square and then tack glued the seems. Once that was dry I was able to remove the wires holding the boat together. I did check that the boat was reasonable true before epoxying the seems. While it maybe wasn't perfect the bubble was between the lines of my level everywhere I checked so I called it close enough.
Since I've taken these pictures I've filleted all the seems in the aft hull and started laying the fiberglass tape around the nesting bulkheads. I hope to finish taping up the interior of the boat this week. I'm hoping to have the boat done by May but if that's going to happen I need to spend more time actually working on it and less time staring at it and daydreaming.
post #24 of 75 Old 03-20-2017
Barquito
Barquito's Avatar
re: Hugh's Log
Looks great! So much fun to see a boat rise out of a pile of wood. It might be a more difficult road, but, I really like the idea of building a boat to learn to sail, that you will later use as a tender for a bigger boat. Are you building the nesting version?
Valiant 32
Barquito is offline
post #25 of 75 Old 03-20-2017 Thread Starter
Dock
re: Hugh's Log
Yes this is the nesting version. I really couldn't store a 10'+ boat where I'm currently living. While the non nesting version is a better boat especially when it comes to bailing it out (It can use a single self bailer and has much more reserve buoyancy ) the nesting version should give me a lot more flexibility when I start shopping for my big boat since I'll only need 5'6" x 4' to store the tender on deck.
post #26 of 75 Old 04-05-2017 Thread Starter
Dock
re: Hugh's Log
Lots of slow progress the last few weeks. I've not gotten all of the interior seams filleted and taped and am about 2/3rds of the way through with the aft seating. I've included a picture of my fancy filleting tools. I figure I have about another days work and then I can flip the boat and start fairing the hull.
WP_20170401_17_47_43_Pro.jpg   WP_20170401_17_50_05_Pro.jpg   WP_20170405_08_35_39_Pro.jpg
SailingUphill and CalebD like this.
No matter where you go, ....
B&B Spindrift 11N
Past Adventures:
post #27 of 75 Old 04-05-2017
Tartan 27' owner
CalebD's Avatar
re: Hugh's Log
Looking very much like a boat. Nice work.
Isn't there a center board slot/trunk?
Everywhere you go, there you are.
Everybody has one:
CalebD is online now
post #28 of 75 Old 04-05-2017
GreenasGrass
re: Hugh's Log
Scorpion apparently suffered no self esteem issues.
ColoGuy is offline
post #29 of 75 Old 04-06-2017 Thread Starter
Dock
re: Hugh's Log
Thanks, there's going to be a centerboard trunk just ahead of the bulkheads. I haven't started building it yet. It'll account for about 2/3rds of the parts I still have lying around.
Lazerbrains likes this.
B&B Spindrift 11N
Past Adventures:
post #30 of 75 Old 05-03-2017 Thread Starter
Dock
re: Hugh's Log
Since I last posted I did a fill coat on the interior fiberglass seems and flipped the boat and rounded the chines and filled in all the holes. Now everything is nice and smooooth. I've also started work on the dagger board. The next step is flipping it back over and chopping it in half.
After the plane my second favorite wood working tool is my soldering iron. If any of your temporary (or permanent) screws get epoxied in you can just heat*up the screw with the soldering iron and the screws come right out. You can also use it to remove globs of hardened epoxy. A lot less work then trying to sand them down.
WP_20170502_18_48_48_Pro.jpg   WP_20170502_18_48_19_Pro.jpg   WP_20170502_17_52_05_Pro.jpg
B&B Spindrift 11N
Past Adventures:
New Way To Keep A Log SOUNDBOUNDER Seamanship & Navigation 1 02-09-2012 12:52 PM
Winners of Harbor Destin Boat Parade announced - Destin Log and Walton Log NewsReader News Feeds 0 12-06-2011 02:20 AM
The Log Investigates - Abandoned Boats Plague Mission Bay in Wake - The Log Newspaper NewsReader News Feeds 0 03-08-2007 04:15 PM
