Anti fouling Idea - SailNet Community
 4Likes
  • 1 Post By aeventyr60
  • 1 Post By capta
  • 2 Post By FSMike
post #1 of 9 Old 11-16-2016 Thread Starter
SanderO's Avatar
Anti fouling Idea
I got a new Highfield C310 alum. RIB in mid July and splashed it, had it in the water and just yesterday took it out to clean it. YUCK (I'll post pics when grand daughter let's me have my phone). I spent 3 hrs cleaning it... and as I was doing it a fellow who does all sorts of boat varnishing tossed me a comment.... those RIBS are nice but they shouldn't be left in the water... meaning davits or similar. Not possible for how I use our LaniDani... it gets us to our moored boat and stays tied to a town float when when not tied to our stern or ferrying us back and forth. We have no davits and tow it coastal.
IDEA:
Get a cheap - $30 inflatable (Amazon) and place it under the Lani Dani and inflate it... hopefully lifting it out of the water and deflate it when when arrive to use it. This would reduce its in water time to only the weekends and our occasional longer cruises.
Would this work?
Is this idea crazy?
What say you?
SanderO is online now
post #2 of 9 Old 11-16-2016
Re: Anti fouling Idea
Sounds like a poor man's hydro lift.. longevity might be an issue, plus the 'hassle' of de-and-re-flating everytime (but would you need to? just slide the RIB on and off??)
Faster is offline
post #3 of 9 Old 11-16-2016
aeventyr60's Avatar
I have to raise my dink on a halyard just out of the water every night or it's barnacle city in a few days here.
seabeau likes this.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #4 of 9 Old 11-16-2016 Thread Starter
SanderO's Avatar
For me the issue is when I leave the dink from Sunday eve till perhaps Friday afternoon....at the town float. It's too heavy w/ the ON to pull it onto the dock and they wouldn't permit it to be left there. I thought that I could slide the cheapy inflatable underneath and pump it up and get the bottom of the dink out of the water.
post #5 of 9 Old 11-16-2016
Master Mariner
capta's Avatar
Why not pick up one or two of those jet ski floats to park your inflatable on at the dock? They are drive on, drive off and you could probably pick them up cheap during the winter.
RobGallagher likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #6 of 9 Old 11-16-2016
FSMike's Avatar
Nobody uses bottom paint anymore?
RichH and baywater like this.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #7 of 9 Old 11-17-2016 Thread Starter
SanderO's Avatar
Anti fouling is not very effective, expensive, builds up and is messy and time consuming. You still have to scrub the bottom regularly. It's toxic to the environment.
It's not effective and so other non toxic solutions need to be found.
post #8 of 9 Old 11-17-2016
TQA
Bombay Explorer 44
TQA's Avatar
Also be aware of rapid corrosion of the ali bottom if the RIB is left in water all the time.
I am in Grenada and there have been several instances of severe corrosion on ali ribs which are around 3 years old. It seems worst along the edge that is next to the hypalon tube. Dinks have been condemned as unsafe for further use.
TQA is offline
post #9 of 9 Old 11-17-2016 Thread Starter
SanderO's Avatar
This is a problem when the paint does not adhere to the aluminum... and the fabric come free with the loose paint. You need to inspect and make remove corrosion and properly over coat again.
I've had several alum ribs and have had paint issues but not extensive or leading to any leaks or separation. Conceptually it IS a problem. For me hasn't happened.
10 year anti fouling... seriously? BlaZespinnaker Gear & Maintenance 5 08-10-2015 09:37 AM
anti-fouling dubon Gear & Maintenance 2 11-21-2012 08:23 AM
DIY anti fouling Windhorse 166 Gear & Maintenance 3 04-27-2012 02:31 PM
Transducer Anti-Fouling jlmarra Electronics 0 05-13-2011 09:06 AM
Sanding anti-fouling davewild Gear & Maintenance 3 09-09-2009 02:28 PM
