small crack in leading edge of keel attachment - SailNet Community
 1Likes
  • 1 Post By Arcb
post #1 of 9 Old 01-05-2017 Thread Starter
cdy
Looking at a Hughes 35 - early 80's - its out of the water - where the keel attaches to the boat - there is a small crack on the leading edge on both sides of the keel, its small it runs about 5 inches on each side - at the first inch or so when knocking on the keel it seems like their is a bit of a cavity, hollow sound - very small area, the rest of keel and the attachment point looks good, no separation , no distortion to the bottom paint.
Is this something that would require dropping keel or grinding back area and fill ?
cdy is offline
post #2 of 9 Old 01-05-2017
Arcb's Avatar
Re: small crack in leading edge of keel attachment
To me it reads like there may have been a significant grounding.
I do not think I would proceed without having a knowledgeable surveyor inspect the keel and attachment point.
BryanM2016 likes this.
Arcb is offline
post #3 of 9 Old 01-05-2017
al brazzi
We had a 78 model 8.3 way back and there was a gap big enough to to snag crab pots where the washers under the keel nuts went away and everything else was OK. Hauled when we bought, put some 5200 in the gap and rested to Boat on the Keel and tightened everything up, all good. A qualified surveyor will know the difference, if the rest of the Boat looks good get her surveyed.
FWIW Hughes built some Columbia's after they went under, and built some nice Boats.
albrazzi is offline
post #4 of 9 Old 01-06-2017
A pic would help. It reads like you are referring to the keel joint. How big is the separation? Does the cracking extend onto the hull? I can't figure how tapping on the iron/lead keel itself would sound hollow. Is there a keel stub that the keel is attached to that you tapped on?
If there is water penetration into a cored hull, that's potentially a big deal. Find out for sure.
Jeanneau 54DS
Minnewaska is offline
post #5 of 9 Old 01-06-2017
I recently had a similar issue with a boat I was thinking about proceeding with a survey. Check out my post, pics and the great responses from fellow members.
BryanM2016 is offline
post #6 of 9 Old 01-06-2017
Senior Citizen
Chas H's Avatar
Small cracks are not uncommon at the hull keel joint. A survey is a must if you are considering purchase.
If it checks out, after inspection torque the keel bolts on the hard.
The crack can be filled, but use 4200 (which can be removed) instead of 5200.
-CH
Chas H is offline
post #7 of 9 Old 01-06-2017
al brazzi
-CH
Use 5200 and you dont even need bolts
albrazzi is offline
post #8 of 9 Old 01-06-2017
pdqaltair's Avatar
3M 5200 can be remove (Marine DeBond).
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #9 of 9 Old 01-07-2017
Senior Citizen
Chas H's Avatar
Wow! I did not know this stuff existed. It's great to learn new and exciting things about boat repair and maintenance.
-CH
Chas H is offline
How to repair very small crack in Escape Rumba (13' plastic sailboat)? DanielF Gear & Maintenance 13 05-26-2016 10:39 PM
small crack at the base of the mast jhgreen Gear & Maintenance 9 12-29-2012 09:49 PM
Small crack and rust stain on the side of the keel ichorniy Gear & Maintenance 8 01-11-2009 04:11 PM
8.3 Keel Attachment pnwardwell Columbia & Coronado 1 06-22-2008 02:32 AM
Leading edge of my rudder is showing its age ChicagoNewport27 Gear & Maintenance 14 04-22-2007 11:18 PM
