Missing O-rings on ST60 paddlewheel blanking plug - SailNet Community
 1Likes
  • 1 Post By TakeFive
post #1 of 6 Old 02-11-2017 Thread Starter
TakeFive's Avatar
My boat has a ST60 paddlewheel-type speed gauge that I've never used. The blanking plug was in place when I bought the boat last summer, and it stayed there until today. The paddlewheel needed cleaning up, and I also wanted to practice removal/replacement while on the hard to make sure nothing catastrophic happened when I first tried it.
So today, while on the hard, I cleaned up the paddlewheel and also removed the blanking plug and cleaned it up too (see attached pic). Upon inspection, it looks like there are two O-rings missing from the plug's shaft (though there are still two O-rings at the top of the plug). Based on the dirt that was present (before I cleaned it up) there is definitely water that entered the annulus around the plug's shaft, but no sign that any of it leaked past the other O-rings at the top.
The paddlewheel insert also has the two O-rings at the top, and one lower O-ring in the shaft near where the ones are missing from the plug.
I'm curious whether others have all 4 O-rings on their ST60 plugs, or have the two lower ones missing like on mine. I don't want to add them if they're not supposed to be there. In fact, it looks like they could cause more harm than good. If you read the link below, you'll see that water can get between the O-rings and freeze, causing the through-hull casing to crack:
https://forums.sailboatowners.com//i...series.140420/
So maybe Raymarine/Airmar opted to remove the lower O-rings from the plug's design, which would allow water to drain from the annulus upon haulout, preventing ice damage if someone were to forget to remove the plug while on the hard.
Just curious to hear all of your experiences with this, and whether you think I should get some additional O-rings for the plug.
edel665sailor likes this.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #2 of 6 Old 02-11-2017
Re: Missing O-rings on ST60 paddlewheel blanking plug
Thanks for the link.
Sent from my SAMSUNG-SM-G900A using Tapatalk
edel665sailor is offline
post #3 of 6 Old 02-12-2017
BarryL's Avatar
Hey,
Mine has just the upper rings like in your pic.
The plug gets installed in the late fall when the boat gets wet stored and the speed transducer installed in the spring when the boat gets recommissioned.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #4 of 6 Old 02-12-2017
chef2sail's Avatar
Originally Posted by BarryL View Post
Hey,
Barry
I don't have the bottom rings on mine either. We leave the plug in all the time and pull it and replace with the paddlewheeel whenever we feel we want to use it. Not much water gets in.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #5 of 6 Old 02-13-2017
Irrationally Exuberant
I had the same thought when I looked at mine a couple of years ago, so I "fixed" it by adding another O ring. Big mistake. That ring jammed in the little trap door in the thru hull that limits water inflow, so that I could not get it out no matter how I tried. A brute force yank finally did it, but it broke the the little door. I fixed the door, and now leave well enough alone :-)
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #6 of 6 Old 02-14-2017 Thread Starter
TakeFive's Avatar
Interesting, and that's something that I had worried about also.
But here's the odd part - the paddlewheel insert does have an O-ring down near the same location. (Sorry, I didn't get a picture of that one.) So why doesn't it jam the trap door in the same way? Just some food for thought. I'm not planning to add an O-ring to my blank, but wondering if I should remove the O-ring from the transducer. Since I've got the paddlewheel inserted right now, maybe I'll try to remove it and see if I have the same problem you did. I was careful to lube it first - could that make a difference?
TakeFive is offline
Paddlewheel cleaning: Best Practices? nhsail Gear & Maintenance 15 07-16-2016 03:05 PM
Paddlewheel antifouling seaner97 Gear & Maintenance 30 04-27-2016 01:12 PM
will ST60+ transducers work with ST60 instruments? Quickstep192 General Discussion (sailing related) 0 01-09-2010 07:55 PM
Source for ST60 paddlewheel plug Quickstep192 General Discussion (sailing related) 1 12-31-2009 01:11 PM
blanking gate valves aquagee Gear & Maintenance 2 04-26-2009 01:03 PM
