Bending starboard - SailNet Community
 1Likes
post #1 of 11 Old 03-04-2017 Thread Starter
Bending starboard
Has anybody curbed starboard by heating it up maybe like in an oven?
1985 O'Day 26'
I spent all my money on booze, boats and broads. And the rest of it, I wasted. - Elmore Leonard
Bruce3966 is offline
post #2 of 11 Old 03-04-2017
Re: Bending starboard
I've never tried it with that product, but sure you can.
Now to what degree and giving what integrity are other questions.
Try getting a company tech guy to give you some info...even things they have tested but do not recommend.
RegisteredUser is offline
post #3 of 11 Old 03-04-2017
overbored's Avatar
You can heat bend starboard We have used a hot air gun. Free bending it takes some practice and it will warp in two direction when heated in an oven .think potato chip. Without a form it tends to go where it wants which is not always where you might want it to go. narrow strips are easy, bending a large sheet can be a challenge. if you want to bend it to corner it is best to use a strip heater like used on plexiglass.
There are several You tube video's on bending King Starboard
"GOLD RUSH" PRINDLE 16
overbored is online now
post #4 of 11 Old 03-04-2017 Thread Starter
Thanks. I have a 14" x 12" and 1/2" think I need to bend slightly. I am installing a ladder on my O'Day Daysailer on the transom and the rear deck shell is very think so I want to beef it up and glue that starboard underneath the deck and both through both. The curve is very shallow so it should work.
1985 O'Day 26'
post #5 of 11 Old 03-04-2017
You can probably bend starboard to match the curve, but it won't do anything beneficial while it's there. Starboard does not work for backing plates, it is too soft and will just cold flow away from the bolts.
Greg
Stumble is offline
post #6 of 11 Old 03-04-2017
overbored's Avatar
Starboard 1'/2" thick should be ok. the problem with using starboard for a back up is it is to flexible and compresses when through bolted. for ladder where the load is not constant it should be ok but should never used for back up where there is constant load because it will deform under constant load. a better way to do the backup is to epoxy bond a piece of 3/16" to 1/4" thick fiberglass sheet or G10 sheet to the inside and then through bolt. it can also be curved with heat.
post #7 of 11 Old 03-05-2017 Thread Starter
I am glad I asked this. So a G10 sheet would be better huh? No problem, I will do that and order a sheet. Can that be bent at all to a small curve?
1985 O'Day 26'
post #8 of 11 Old 03-05-2017
A 1/8 to 3/16" SS plate would probably be less expensive and would form nicely to the transom once you start bolting it up.. In case of a compound curve, whatever you use should be bedded in thickened epoxy to fill the voids.
Faster is offline
post #9 of 11 Old 03-05-2017
You don't bend the bācking plate, you gap fill with thickened epoxy.
Greg
Stumble is offline
post #10 of 11 Old 03-05-2017
overbored's Avatar
for your boat I would use two pieces of 1/8" thick one on top of the other, as they will bend to the shape of the transom. think bent plywood. fit them to the area and though bolt them with the ladder bolts and use thickened epoxy to bond them together and to the transom. this will make multi ply backup that is parallel to the outside surface that does not use a lot of epoxy filler. using a large amount of filler to fill a gap can cause the filler to exotherm, will get very hot and can cause the transom fiberglass to warp and can also ruin the gelcoat finish. the bonded layers of material will be very strong and give some thickness. you could layup more fiberglass on the area but that would be a lot harder to do in a confined space.
to save some money Mcmaster Carr has fiberglass sheet in may sizes and works just as good as the very expensive G10. https://www.mcmaster.com/#standard-f...heets/=16mi49l
I use the white chemical resistant under batterys and the gray/Flame retardant in engines compartments. it comes in 1/8" 12x 12 sheet for $12 and not the ugly color of the G10
Bending a Sheet krozet Gear & Maintenance 11 04-25-2010 03:37 AM
Anchor bending Jhildy Gear & Maintenance 4 01-12-2009 10:45 PM
T-Track bending mentalfee Gear & Maintenance 4 06-19-2007 10:03 PM
bending the mast bkw Racing 6 12-16-2006 07:58 PM
Bending Spars Dan Dickison Gear and Maintenance Articles 0 09-26-2001 08:00 PM
