Weird Roundup under bridge... - Page 2 - SailNet Community
 4Likes
post #11 of 21 Old 04-13-2017
Re: Weird Roundup under bridge...
Pretty sure we're talking about a bridge without a tender and an airdraft of maybe 100ft, with abutments rather far part too. Yes?
Jeanneau 54DS
Minnewaska is offline
post #12 of 21 Old 04-13-2017
krisscross's Avatar
Yes, that is a pretty much standard fixed bridge over ICW
Plato
krisscross is online now
post #13 of 21 Old 04-13-2017 Thread Starter
Yes, regular ICW bridge, about 64ft of clearance. Pretty wide. Used to get engine running but now feeling a little more confident. Motor wouldn't have helped this. This was a roundup, pure and simple. My fiddle block on the main sheet has a cam cleat that faces down. So, a little snap of the sheet down lets it go, a little pull and lift up and it locks. It's the only one I ever worked with, so I don't know what else is out there. Sure glad I didn't hit that fender, it would have been bad. I don't need any problems like that. Boats get dismasted like that, right? kev
FloridaBoy is offline
post #14 of 21 Old 04-13-2017
fallard's Avatar
It looks like there is a 600' opening by the old bridge approaches and it would appear the currents are minimal--probably peaking at much less than 2 kts. The fixed Rt 520 bridge vertical clearance is 65' and its horizontal clearance (channel center) is 90', with a total span of about 1600' (shore to shore). You would have to watch for traffic in the opening, but the waterway appears to be very wide on either side of the opening.
fallard is offline
post #15 of 21 Old 04-13-2017 Thread Starter
No currents. It's a bog, or more precisely, a lagoon. It is a rare thing to have a current. It's 30 miles north and south to any inlets. Sebastion to the south and Ponce inlet to the north. Fifteen years ago, you could see the bottom from the boat in 12 feet of water. See the grass waving. Now, it's a mud hole. Brown algae. Runoff. I dive on my boat to clean bottom, good viz is 2-3 feet, maybe. Nothing but mud on the bottom. No sunlight gets through. Poor lagoon, killed by man. Spent the last 30 years on the Indian River, hope it comes back someday. kev
post #16 of 21 Old 04-13-2017
RichH's Avatar
Originally Posted by FloridaBoy View Post
Must have been a vortex or something there under the bridge. Great learning experience and I'll be a lot more alert next time I go under a damned bridge. Kevin
TWO 'possibles' here
Could have been a wind vortex cause by the shape of the bridge structure; OR, could have been a combo of an aerodynamic 'rotor' - PLUS, an increase in water velocity in close proximity to and as deflected by the bridge structure during tide flow (or simply being too close to structure when the boat is 'at speed').
In the case of a water velocity increase (from tide rip, etc.) due to water 'deflection' by the structure ... the zone of higher speed water will tend to 'suck' you into the structure. If interested in the technicals, do web search for "vena contracta".
This is the very same reason that LARGE ships do not / will not pass close to one another when at speed ... as the increased water velocity of the between the two (plus a generated 'trough' of water between the two ships) will tend to cause each to get 'sucked into' one another ... all due to anomalies of 'hydraulics'.
Its good you survived unscratched, which is the best part of any 'surprise' education.
RichH is online now
post #17 of 21 Old 04-13-2017
Old as Dirt!
svHyLyte's Avatar
Bernoulli lurks at the base of every bridge...
RichH and chef2sail like this.
svHyLyte is offline
post #18 of 21 Old 04-13-2017
Seņor Member
ottos's Avatar
FB - Did you have any jib out?
ottos is offline
post #19 of 21 Old 04-13-2017 Thread Starter
130% jib out. You know, I know what you guys mean, going fast, too close to the fender. I have never gone under that bridge going that fast, under sail. Usually 2 or 3 knots, real slow, mostly with the engine on and in gear, cause of the slow speed. That might have been a factor, along with a puff. kev
post #20 of 21 Old 04-14-2017
cdy
Its a fixed bridge - no bridge tender, not much current, tide in Cocoa - most likely just a wind incident( not current related) my boat is moored just on the southwest side of the 520 bridge,
cdy is offline
Weird weird july weather..... oysterman23 General Discussion (sailing related) 21 07-09-2014 06:43 PM
Local Roundup: Conn sailing wins Intersectional NewsReader News Feeds 0 09-19-2011 03:10 AM
Monday Midday News Roundup - Cbs 5 NewsReader News Feeds 0 01-29-2007 04:15 PM
Local roundup (The Providence Journal) NewsReader News Feeds 0 11-21-2006 01:15 AM
AAA's Great Battery Roundup April 22nd NewsReader Mass Bay Sailors 0 04-20-2006 12:15 PM
