Cleaning shackles - SailNet Community
 3Likes
  • 1 Post By Jim_W
  • 1 Post By CalebD
  • 1 Post By hellosailor
post #1 of 4 Old 08-21-2017 Thread Starter
Cleaning shackles
What's the best way to clean white stuff off rigging equipment?
Sent from my iPad using Tapatalk
jjwoods5 is offline
post #2 of 4 Old 08-21-2017
Sailor
Re: Cleaning shackles
They are called hanks not shackles. I would spray them with some McLube if they still work good if not they cost about $8 each if they need replacing
jjwoods5 likes this.
Jim_W is online now
post #3 of 4 Old 08-21-2017
Tartan 27' owner
CalebD's Avatar
Clean with vinegar first with toothbrush or similar.
Then lube with McLube or similar.
Done.
Everybody has one:
CalebD is offline
post #4 of 4 Old 08-22-2017
Looks like the white crud is on the GROMMET in the SAIL and not on the hanks at all. The hanks have green verdigris but that's normal unless you want to be polishing brass every week.
What the grommets are made of and why they have white crud is another issue. It could be the grommets are deteriorating and need to be replaced. Or the vinegar might work, or some careful work with a Dremel might be needed.
White crud on grommets? Wonder what that is.
hellosailor is offline
Plastic shackles jballou Gear & Maintenance 3 05-31-2016 07:15 AM
Soft Shackles bird song Gear & Maintenance 14 12-22-2015 12:24 AM
Plastic Shackles - Where to get? jballou Gear & Maintenance 4 07-07-2015 07:24 AM
Spinnaker shackles Classic30 Racing 20 10-07-2014 03:26 AM
Get mooring shackles off Barquito Gear & Maintenance 8 10-06-2010 06:02 PM
