Rigging gybe preventer - SailNet Community
 6Likes
post #1 of 11 Old 08-24-2017 Thread Starter
My boat has a wooden toerail. Where can I attach a block to rig a gybe preventer? There are two spring loaded blocks on the genoa track but they don't appear to be substantial enough. I can see how to rig a snatch block to a stanchion base but that would lead to deck damage. Thanks.
zeehag likes this.
FirstCandC is offline
post #2 of 11 Old 08-24-2017
ASA and PSIA Instructor
Re: Rigging gybe preventer
I just disconnect the bottom of the vang tackle and reconnect it to a stanchion base. You can install some pads but you arn't likely to make them any stronger than a stanchion base.
Sent from my SM-G900V using Tapatalk
sailingfool is offline
post #3 of 11 Old 08-28-2017
jackdale's Avatar
Do you have a pad eye on your foredeck? A preventer led from the boom end to a block on the pad eye and back to the cockpit is far better than a toe rail or stanchion point.
Using the vang is an invitation to a bent or broken boom.
knuterikt and Lazerbrains like this.
jackdale is offline
post #4 of 11 Old 08-28-2017
I tried using the Dutchman system and was never able to properly use it so I just sold it. My cabin top is too high, and I would never be able to have any tension on the line for the Dutchman thing to work. I am now looking at possible solutions. It's hard without pictures. I really don't understand most of the explanations I find on how to setup a preventer. It still baffles me and it's something I have to figure out before I head out to the Caribbean.
gauchomexica is online now
post #5 of 11 Old 08-28-2017
jackdale's Avatar
I really like boom brakes. Too bad your did not work out.
Good diagram. Iffy spelling.
jackdale is offline
post #6 of 11 Old 08-28-2017
Make sure you use quality parts. I was doing an off shore race on a boat that had a Chinese part (can't remember the part though) that broke leading to a "Chinese gybe" and oddly enough I was warming up some chicken fried rice on the cooker at the time. What are the odds?
I remember now - it was a snap shackle.
zeehag and jjwoods5 like this.
ScottUK is offline
post #7 of 11 Old 08-28-2017
Originally Posted by jackdale View Post
..... is far better than a toe rail......
Why do you think a slotted AL toe rail would be bad use?
RegisteredUser is online now
post #8 of 11 Old 08-28-2017
Just cleat the preventer at one of the bow dock cleats?
Corrotoman is offline
post #9 of 11 Old 08-28-2017
al brazzi
I've said it before but, be sure you use enough line to let the boom over, for when you gybe not if. This might be the "Chinese Gybe " Scott refers to.
albrazzi is online now
post #10 of 11 Old 08-28-2017
jackdale's Avatar
The "modern" toe rails which are screwed into a plate lack the necessary strength. An older one, though bolted, might work but I have seen them deformed; that might compromise the hull deck join.
knuterikt likes this.
jackdale is offline
Gybe set, gybe drop uvs General Discussion (sailing related) 5 12-31-2012 03:50 PM
Poll about gybe preventer - when do you use one? MarkSF Gear & Maintenance 22 08-22-2012 09:19 PM
Installing Wichard GybEasy gybe preventer MarkSF Gear & Maintenance 0 04-16-2012 10:28 PM
Rope for gybe preventer on 30ft boat MarkSF Seamanship & Navigation 19 03-30-2011 07:23 PM
where to attach end-boom gybe preventer ArgleBargle Gear & Maintenance 5 03-10-2009 03:23 PM
