Hurricane Irma - On the Hook - SailNet Community
 41Likes
post #1 of 84 Old 09-01-2017 Thread Starter
Just looking for general advice. I'm watching the track of Hurricane Irma and hoping the current HP system strengthens and drives it south of the VA/NC Coast. Either way on Wednesday I'm putting my boat on the hook as a precaution (and also for the experience as it will only be the 2nd time Ive been on a mooring). Any advice on how to prepare the boat (and myself) would be helpful. 1986 289 Oday. Will be near the head of the Chesapeake near Aberdeen, MD
Thanks in advance.
Bluemax009 is offline
post #2 of 84 Old 09-01-2017
Learning the HARD way...
eherlihy's Avatar
Way too early to worry about it.
If it does become a concern, here is what I have done for storm prep for my O'day 35:
Jib comes off.
Main gets secured to backstay, and wrapped with a dock line around sailcover.
Dodger comes off.
My single support Bimini stays in its cover.
On a slip, I have always doubled the lines and centered in the slip. My neighbor and I have worked in concert to keep our boats centered in the slip, and off of each other.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #3 of 84 Old 09-01-2017
bristol299bob's Avatar
Re: Hurricane Irma - On the Hook
I strip everything, it all comes off and gets stowed below:
- jib
- main
- halyards (replaced with messenger lines)
- dodger
- bimini
- lifesling
- grill
- anchor
- man overboard pole
full disclosure: I forgot the stow the MOB Pole during hurricane Matthew. Matthew stowed it for me ... just not where I wanted it stowed.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is online now
post #4 of 84 Old 09-01-2017
kd3pc's Avatar
BlueMax
Odd opinion here, but where is your boat usually stored??? The idea of putting the boat on the hook (Anchor???) or mooring..where there will be only one thing linking the boat to the point....I would and have, run the boat up the nearest creek, aground or close to it and tether it to the sides of the creek, using several lines to do so.. We have installed several boats "up the creek" over the years and have had significantly less damage than watching one dance on a mooring or anchor lead..or worse breaking loose and running wild.
Either way, remove anything that can be removed, sails, canvas, frames and even winch covers (seldom make it through a strong blow) and tie down the rest using multiple paths and lines. We even bring home electronics and high value things that can be removed.
oysterman23 likes this.
kd3pc is online now
post #5 of 84 Old 09-01-2017
contrarian's Avatar
- jib
- main
- dodger
- bimini
- lifesling
- grill
- anchor
The above is very good information, I would also add that if you are anchoring that you use the heaviest anchor that you can get your hands on and still be able to deploy.
Use lots of scope preferably with chain and a long bridle snubber, double up on chaffing gear (ie fire hose and the like) Try to position the boat where you will have the most protection from the strongest anticipated wind direction and where you are less likely to be dragged down upon by other boats that don't take the same level of precaution that you do. Of course once the wind goes above 100 mph it's pretty much just a crap shoot. This is my plan anyway. I've got a 65 lb. Mantus with 165' of 3/8" G4 chain and and a bridle made up of 35' of 7/8" three strand on each side which attaches to a chain bridle that goes around the bow cleats. The end of the chain is also attached to a single snubber that goes back to the primary winch and then to the stern cleat. All of the tackle on the boat is enclosed in two layers of fire hose, a 2/12" which is in a 5". There are others that disagree with this approach and they may be right but this is the choice that I made and I'm sticking to it.
seabeau likes this.
contrarian is offline
The Following User Says Thank You to contrarian For This Useful Post:
timangiel (09-04-2017)
post #6 of 84 Old 09-01-2017
Freedom Chip Counter
scubadoo's Avatar
Strip it bare! Tie on fenders or other means of keeping boats and floating objects off yours. They may also keep your boat above the waterline if it gets holed.
timangiel likes this.
Tartan 31
scubadoo is offline
The Following User Says Thank You to scubadoo For This Useful Post:
post #7 of 84 Old 09-01-2017
Watch this video of Cat 4 hurricane Harvey and then figure out what kind of ground tackle you think you'll need to handle these conditions...
My take? Take shelter and write off your boat.
smackdaddy is offline
post #8 of 84 Old 09-01-2017
colemj's Avatar
Why not hope it stays out to sea instead of just hitting people other than you?
Mark (boat currently South of VA/NC)
scubadoo, seabeau and AJC506 like this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #9 of 84 Old 09-01-2017 Thread Starter
Thanks. After reading this I may just center in the slip and double line. Appreciate the feedback. ?
post #10 of 84 Old 09-01-2017 Thread Starter
- jib
- main
- dodger
- bimini
- lifesling
- grill
- anchor
The firehose is something I've never really thought of but a good idea. Why would some disagree with this? Seems like a reasonable and appropriate method to mitigate some of the risk...
Introducing IRMA VIEXILE Weather 126 12-05-2017 05:33 PM
Best Boat Hook? MedSailor Gear & Maintenance 35 07-09-2016 04:24 PM
hook scraper stevieb7 General Discussion (sailing related) 11 01-15-2013 08:56 PM
Reefing Hook shogan50 Islander 1 08-10-2011 07:31 AM
hi from the hook chrisncate General Discussion (sailing related) 2 07-18-2010 07:25 AM
