Cal 29-2 cross beam question - SailNet Community
post #1 of 3 Old 01-01-2018 Thread Starter
cdy
Have agreed to price with seller on a late 70's Cal 29-2 - have to do a more in depth inspection this week - I know Cal boats pretty well - the price is low and feel pretty confident in my ability to identify any possible problems - - however one area that seems specific to this model - a steel cross beam under the bulkheads that also help support the mast - I know they have been know to rust and cause problems - I don't see any low areas around the mast and the rigging seems tight ( boat has been on the hard for about a year) - so I don't think the beam has deteriorated much over the past year at least - what I am not sure of - is how to inspect it - can you see from bilge? - do you have to look at it from the sump area in the head - or do you need some sort of flexible camera to stick inside to get a look?
It looks like a pretty intense repair if it has problems -
cdy is offline
post #2 of 3 Old 01-01-2018
krisscross's Avatar
Re: Cal 29-2 cross beam question
This steel cross beam is present is several Cal boats. This is what they usually look like when out of the boat:
More general info here: https://www.boatdesign.net/threads/m...-cal-28.44632/
Plato
krisscross is online now
post #3 of 3 Old 01-01-2018
Lazerbrains's Avatar
You need a borescope to check it.
Even though you don't see low areas doesn't mean it is not rusted out - they typically are going bad.
The question is how much risk do you want to take with it - ignorance is bliss?
There are commercially made replacements. Cal 29's are good boats and replacing the compression beam would not be a deal breaker for me - I can think of more difficult things to have to fix on a sailboat.
Lazerbrains is online now
Cal 29 beam rot tommays Cal 31 06-13-2018 11:05 AM
What is a Cal 29 worth that needs the beam replaced? E Be Cal 14 06-30-2016 09:01 PM
Cal 29 Beam of death fossil Cal 8 01-24-2016 03:09 PM
Trailer- cross beam weld jtrask Gear & Maintenance 5 04-11-2013 12:31 PM
CAL 36 compression beam pictures kapitany Cal 5 08-11-2010 09:48 AM
