What would you build? - SailNet Community
 24Likes
post #1 of 74 Old 01-09-2018 Thread Starter
Dock
So lets pretend that you've decided that you wanted to build a boat to sail all the oceans blue. You'll be building this boat with your own two hands and you want to get it done in a reasonable amount of time, lets say less than three years working on it full time. What would you choose to build?
thanks,
Hugh
No matter where you go, ....
B&B Spindrift 11N
Past Adventures:
ThereYouAre is online now
The Following User Says Thank You to ThereYouAre For This Useful Post:
timangiel (01-09-2018)
post #2 of 74 Old 01-09-2018
Master Mariner
capta's Avatar
Re: What would you build?
Jim Brown Searunner 37 or 40, without any hesitation. There is even a construction manual specifically written for the back yard builder, available free online. It even includes the mast and vanegear!
Since I choose not to build myself, I'd have one built in carbon fiber, if I won the lottery! lol
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #3 of 74 Old 01-09-2018
Moderator
Arcb's Avatar
Okay, well I don't have enough experience with home built boats, or all the oceans to give a recommendation.
I do have a couple of thoughts. When you say all oceans, are you including the ones at the top and bottom? If so, I think steel would be a good idea. I think aluminum welding can be a handful for the home builder.
If not, I think my preference would be for a multi hull. I have often dreamed of building a small Wharram. I don't really know much about the bigger ones, however, they have a really useful chart on their website that gives both time and dollar estimates for building boats of different sizes.
Https://www.wharram.com/site/choosing-a-design
Arcb is offline
post #4 of 74 Old 01-09-2018 Thread Starter
Dock
Is there anything particular that draws you to the Searunner? While I believe that trimarans are the ultimate sailing machines they seem to be the least practical when it comes to cruising/living aboard.
I probably should have added that you plan on spending a decade or more in your pursuit of crossing all the worlds oceans.
thansk,
Hugh
B&B Spindrift 11N
Past Adventures:
post #5 of 74 Old 01-09-2018
amwbox's Avatar
Something like an Ingrid 38, in a ketch, from oak. kick it old school. But not too old.
ThereYouAre likes this.
"Freedom is the increased knowledge of what you can do without." —Thoreau
amwbox is offline
post #6 of 74 Old 01-09-2018 Thread Starter
Dock
While spending extended periods of time at high latitudes isn't part of the daydream, you'd certainly want something that could round all the great capes in relative safety.
The small catamarans do seem to provide the best combination of comfort and performance. I've been spending a lot of time on Richard Woods' site (Sailing Catamarans - Home) and was curious as to what else was available and suitable. I'll be spending some time on the Wharram site now.
thanks,
Hugh
B&B Spindrift 11N
Past Adventures:
post #7 of 74 Old 01-09-2018
Master Mariner
capta's Avatar
thansk,Hugh
I'm pretty sure you meant to say I rather than you in the above statement, as I already have.
I sailed a Searunner 37' from Pago Pago to the USVI via the Red Sea and the Med. I consider it the perfect family ocean cruising boat for a variety of reasons, not the least of which being that the mast is in the cockpit, so all your sheets and halyards are close at hand. Another being that the vanegear was designed as an integral part of the boat.
I sailed mine out of a hurricane in the Indian Ocean and through a storm in the Atlantic that took the lives of at least 12 people I am aware of, including Alan Colas, without any problems, but certainly not without hard work. I also sailed her 1200 miles up the Red Sea, no small feat, as the course up the Red Sea is roughly 15 degrees off the wind.
capta is online now
post #8 of 74 Old 01-09-2018 Thread Starter
Dock
Thanks, but I won't be felling and milling the lumber
B&B Spindrift 11N
Past Adventures:
post #9 of 74 Old 01-09-2018
amwbox's Avatar
Will be amazing if those guys pull it off. Can't wait.
amwbox is offline
post #10 of 74 Old 01-09-2018 Thread Starter
Dock
On building a multifull vs a monohull I'm thinking that the multihull would actually be a lot less work and allow simpler building techniques. You'd need to build 26,000lbs of boat for an Ingrid while only 11,000lbs of boat for a Searunner 37, or 12,000 lbs for a Woods' 38' Transit catamaran.
B&B Spindrift 11N
Past Adventures:
Build from the inside out???? deltaten Sailboat Design and Construction 13 10-03-2015 09:15 AM
I'm new here and new build Manninge Introduce Yourself 7 07-10-2014 01:12 AM
Build Quality? OldFrog75 Sailboat Design and Construction 8 04-10-2013 02:19 PM
Build your own SSB? jamesorr General Discussion (sailing related) 8 02-13-2013 10:52 PM
You can't build a boat until you can do this... Giulietta Sailboat Design and Construction 26 11-08-2007 02:53 AM
