Why paint topsides? - Page 3 - SailNet Community
 5Likes
post #21 of 26 Old 02-19-2018
celenoglu's Avatar
Re: Why paint topsides?
Fiberglass is translucent, gell coat or paint covers the fiberglass and light cannot penetrate. I only like sunshine through the windows not from the "walls"
celenoglu is online now
post #22 of 26 Old 02-19-2018
SeaStar 58
You are making assumptions that are not remotely close to reality. The vast majority of sailors in my part of the continent will NEVER take our boats to the scorching tropics...an in-white boat works fine.
Furthermore, the last time we drove our 'Inferno Red' Charger through the 100 plus degrees of the American desert, we enjoyed the drive just fine.
Last edited by paulinnanaimo; 02-19-2018 at 11:53 AM. Reason: spelling in-white should be un-white
paulinnanaimo is online now
post #23 of 26 Old 02-19-2018
Sorry, the computer self corrected. The above should read non white instead of in white.
post #24 of 26 Old 02-19-2018
Originally Posted by amwbox View Post
You could spray a boat in gelcoat...if your willing to take on the crazy amount of sanding to get a nice finish out of it. Only reason it looks nice on a new hull is the fact that it was sprayed on the inside of a mirror finish mold under controlled conditions. It can't be tipped out beautifully like 2 part urethane... you're going to have to sand, sand, sand if you want it pretty.
Truly, the nicest finish will come from a quality LPU paint...and it can be tipped out to near perfection with a little practice and properly thinned. Gelcoat lasts longer, but its a lot more work and not as nice looking as paint can be. But I still say maintain good gelcoat as long as you can.
That's the part that I didn't know . . .well, one of them.
DonScribner is offline
post #25 of 26 Old 02-19-2018
Originally Posted by paulinnanaimo View Post
SeaStar 58
However I am and have been only speaking to living in and visiting the Humid Tropical area where I live not the Desert where if you hang your clothing on a line the first item may already be dry by the time you put the last item on the line. I live 365 days a year in a Tropical area where on a hot humid day things can take a long time to air dry.
SeaStar58 is offline
post #26 of 26 Old 02-20-2018
roverhi's Avatar
I live in Hawaii. My Cars are white and silver with light colored interiors. Much of the time don't use A/C. Not the case with a dark ezreioe and black interior.
Painted the boat a lightish blue gray for the top sides with an off white deck. Hasn't been bad for comfort. Didn't even consider dark blue or black for two reasons. Temperature gain was secondary to wear issues. Dark hulls show the dings and scratches of normal use and look way worse from fading than a light color. Still wasn't going to pay all that money to have the boat painted white. Would not recommend painting a boat if you can buff the gel coat out and restore an acceptable finish. Gel coat is way more abuse resistant than paint no matter what the color.
roverhi is offline
Topsides? rbyham General Discussion (sailing related) 4 09-28-2015 06:56 PM
Gelcoat or Topsides paint? leogallant Gear & Maintenance 1 09-14-2012 10:41 AM
Reflective Paint on Topsides?? SuzySailor Gear & Maintenance 14 02-07-2007 07:40 PM
Peeling topsides paint Saylorman Gear & Maintenance 4 12-22-2005 08:10 PM
topsides paint JimOppy Gear & Maintenance 2 11-10-2003 03:06 AM
